Cold A/C but No Heat!
Old Oct 3, 2011 | 12:45 PM
Racer343's Avatar
Default Cold A/C but No Heat!
Hi Everyone,
Still playing with the new to me '02 3.0, since it's been 95+ degrees this weekend I've only had the a/c going but tried the heater this morning and no luck. I gave it a bit to cycle through but nothing...
There's coolant in the overflow tank and can't hear any sloshing sounds (ala Land Rover), would somehting like this be a faulty DCCV or should I be looking elsewhere?
Thanks!
Andrew
Old Oct 3, 2011 | 01:57 PM
That's the opposite problem to the usual one reported.
The failsafe on the valve is open so you should get heat.
I would check for an airlock first, I don't suppose someone has bypassed the valve to solve a heat problem?
Old Oct 3, 2011 | 03:07 PM
Racer343's Avatar
Norri,
Anything is possible, I've noticed some screw type hose clamps on some small diameter coolant hoses towards the top of the motor; where should I be looking for a possible bypass?
Old Oct 3, 2011 | 05:12 PM
The two outlets from the valve run up the inside of the passenger wing and connect to metal tubing.
With a 02 you will have the 5 hose valve, so I'm not certain of the layout down at the valve.
I've currently got two pairs of vise grips clamping mine off so that the wife doesn't get toasted until I can get home and fix it.
She hasn't complained since labor day so it must be working.
Old Oct 4, 2011 | 10:35 PM
msnyder52's Avatar
You probably don't have the same issue, but when I first purchased my S it had no heat. The previous owner had hidden the faulty climate control module by splicing in a small piece of hose with a wooden plug in it. It took me a while to figure that one out!
Old Oct 7, 2011 | 01:25 PM
Racer343's Avatar
Before I do any snooping around I wanted to check some obvious things off the list-
I imagine that a cooling system bleed wouldnt be necessary since my temp gauge doesn't show anything out of the ordinary, no spikes at all; am I correct in that assumption?
Going to test if the hoses are warm coming out of the heater core, are faulty heater cores common on S-Types?
Doesnt sound like its the DCCV since I have A/C, is this something that could be eliminated as well?
Any thoughts are greatly appreciated.
Andrew
Old Oct 7, 2011 | 01:50 PM
bfsgross's Avatar
Andrew, your asking for heat when it's 90 degrees outside...do you have the automatic climate control off/disengaged, used the climate mode button (manual operation) and set temp.? The engine coolant temp. gauge measures engine coolant temp. of engine cooling circuit. You're concerned with the cabin heat circuit. Airlock (air bollus) in the heater core route can prevent sufficient hot water to circulate through the heater core. Snoop around some more.
Old Feb 17, 2014 | 01:51 AM
whiteboi's Avatar
which two hoses did you clamping off is there any way you can send me a picture
Poet
Feb 7, 2025 02:18 PM
bdboyle
Sep 16, 2019 05:58 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Darrenmb
Sep 27, 2015 08:43 AM
42Ajd
Sep 26, 2015 07:04 PM
