Cold Start - "Lurch" Restricted Performance
Old Nov 17, 2010 | 02:37 PM
SPECTOIL's Avatar
jejeje ... ok.. sorry for missed "U". Against, thanks in advance for the support!!
Old Nov 17, 2010 | 05:10 PM
SPECTOIL's Avatar
OK..
To go to my house, put in D the knob, and again the failure began. I stopped then turn off and on my car, continue on D, and quickly the gear box fault appeared.
After turning it off and on, put the knob in 3, and ran quite fast, then move the switch to 4 and then to D and so I get to my house.
Do you think of something electronic?
Old Nov 17, 2010 | 05:23 PM
SPECTOIL's Avatar
OK,
I have the code. The only code I have is P0795 "Pressure Control Solenoid "C ". I don't deleted the code of the car's computer still waiting for your suggestions!
Old Nov 18, 2010 | 01:17 AM
JagV8's Avatar
First you need to be sure the battery is good. How old is it?
Also, Search here (on the code) or in this case on google for:
jaguar P0795
and do some reading. Worst case looks like a gearbox shop to mend it and fairly cheap - it's DIY if you're experienced at car DIY. However, be sure it's not a fake code due to a failing battery!
Yours is the Ford 5R55N box. The code is stored in the PCM (which is a combined TCM also for your era car), so you can clear it and see if it reappears. Search on here for that ford number and you'll see the usual failures and what people did.
Old Nov 18, 2010 | 06:45 AM
SPECTOIL's Avatar
Hi jagV8..
Thanks for the support!!!
First: Today I clear the code with my elm... now the car runs but only use 1-2-3 shifts, I don't feel the fourth and five shift (gears). The Gearbox failure and check engine appear 3 times when I come to my work (@ 60 miles from my house).
I review in that forums and see that is a $5 spring problem, but need put out the solenoid body. Iin other words: need new joints, oil, orings, etc ... right?
The battery have less than 2 years...
How cheap? (approx) Yes, I have some experience repairing cars.
Thanks for all support!!!
Old Nov 18, 2010 | 06:11 PM
JagV8's Avatar
Fairly new battery. OK, it's the gearbox, especially with those miles on the car.
Do the Searches I suggested and also have a look at
sonnax
who describe the spring. I'm no gearbox specialist but the posts from others make this sound fairly cheap and even DIY if you're good.
Old Nov 19, 2010 | 06:02 AM
SPECTOIL's Avatar
Thanks jagv8, I go contact sonnax dealer for the spring and i maybe record a "reparation" video and post here for other members!!
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
XFR_Gold
Sep 2, 2015 12:24 PM
