Coolant reservoir bleed screw:
Old Dec 26, 2014 | 02:29 PM
Wuzupez's Avatar
Default Coolant reservoir bleed screw:
Anyone know if the coolant tank bleed screw has a gasket in it or not? Mine is seeping out no matter how tight I screw it in.
Old Dec 26, 2014 | 04:52 PM
Jimmy 68's Avatar
Not sure if there's a gasket or some seal, but from my experience with it, tightening it makes it leak worse.
When I bled mine, I only opened it a quarter turn, then just snugged it closed, and it stopped leaking.
I'd say try opening it up again, then just snug it closed , see if it stops.
Hope its not ruined!
Old Dec 27, 2014 | 04:41 PM
abonano's Avatar
I saw the same question in another (similar) post - there is an o ring.. The part is plastic, so if you over tightened it the o ring is compromised or the plastic threads.
Either way, sounds like the expansion tank will need to be replaced..
Poet
Feb 7, 2025 02:18 PM
X308XJR
May 20, 2019 06:50 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
vwbusbits
Oct 13, 2015 03:43 AM
