Cream oil
Old Sep 23, 2013 | 11:49 AM
Bigblackcat's Avatar
Default Cream oil
Just put engine flush in my s type 4 litre v8 1999 and drain the oil and oil filter but the oil looks watery and beige in colour filled a 4 litre oil can up plus a extra 2 litres came out at least. Car as been sitting for 3 weeks don't do a lot of miles weekend car??????????????
Old Sep 23, 2013 | 12:37 PM
Mikey's Avatar
First, don't use 'engine flush'. Waste of money.
Is the coolant level low?
Old Sep 23, 2013 | 12:50 PM
Maninahat98's Avatar
Is possible that with short trips it doesn't warm up properly/completely and so a lot of condensation/water gets emulsified in the oil.....if you are regularly having to top up the water and you can't see an external leak, then the beige emulsion water content must be coming from a head gasket or a porus block etc. Not aware that these engines suffer from porus block problems though.
Hope it's just that you are doing very short journeys.......once you change the oil, keep an eye on the dip stick and oil filler for the beige-ness....run the engine on longer journeys and make sure it's thoroughly warmed up...15-20 miles should do it, but longer the better.....Allan
Old Sep 24, 2013 | 09:40 AM
No coolent level is not low losing no water?
Old Sep 24, 2013 | 10:42 AM
Mikey's Avatar
If you've got freshly installed oil and it's 'creamy', change it. Go for a nice long drive with the new oil installed and have a look at the dipstick afterwards. Should not be creamy at all.
kthrash
Feb 25, 2019 10:20 AM
caldoofy
Sep 28, 2015 08:43 PM
42Ajd
Sep 26, 2015 07:04 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
