Cylinder order in STR
Old May 29, 2011 | 11:34 AM
jagstr03's Avatar
Default Cylinder order in STR
Just found out that I had a misfire in cylinder 3 in my 2003 STR and I plan to swap the coil with another to see if it is the coil, plug, or worse. Unfortunately, I have not been able to locate the cylinder order in my car using the search or FAQ's. Any help would be greatly appreciated!
Old May 29, 2011 | 12:35 PM
JagV8's Avatar
They're all in the photos and PDFs that you cannot get because you are a newbie. You need to follow the newbie instructions you appear not to have noticed so far.
1,3,5,7 are all in the right hand bank with 1 in the front (it's an international standard)
Old May 29, 2011 | 05:55 PM
jagstr03's Avatar
Default Worse now
Originally, I had the following codes:
P0303 and P1316
Cleared the codes and went around the block, now:
P0300
P0303
P0307
P1313
At this point, I am at a loss as to where to start. Should I just take it to the dealer? I was going to swap the coil packs to see if it was the coil, but the codes are much worse now. Any ideas?
Old May 29, 2011 | 06:03 PM
JagV8's Avatar
Either spend time reading previous threads (plenty suitable) or yes find someone to work on it.
The Search feature is good...........
Old May 29, 2011 | 06:48 PM
jagstr03's Avatar
I have spent the last couple of hours searching through the site and have not found many instances of people fixing multiple misfires in the same bank, just lots of money thrown around with no sure fix in sight. I just purchased the car 1.5 months ago and don't want to commit more money than needed for a fix. Troubleshooting for multiple misses as opposed to a single cylinder doesn't seem to have a standard process unless I am missing something?
Old May 29, 2011 | 09:20 PM
jagstr03's Avatar
Found oil on the plugs and coil packs for cylinder 3 and 7. Anyone know what might cause this? Does the valve cover gasket need to be changed? I have searched on the site, but am not having much luck.
Old May 30, 2011 | 03:06 AM
JagV8's Avatar
Try
Search
chhose Advanced
then appropriate keyword(s)
and just the S-Type forum
then hunt and read
Summary: the coils MAY clean or may be damaged. Up to you whether you fix the oil leak now or later LOL
Old May 30, 2011 | 09:23 AM
Mikey's Avatar
You sure about that? V8s here in N. Am have #1 at the front left as the standard.
Old May 31, 2011 | 11:16 AM
JagV8's Avatar
Maybe those cars don't follow the standard. You can read jag's way (which follows the ISO standard) in the PDF in the FAQs.
Or.... you're not using left the way cars do.
Old May 31, 2011 | 11:51 AM
Mikey's Avatar
Left side reference would be standing behind the car while facing forward. 'Pilot's view' in the aviation world.
Looks like there little consistency in which cylinder is #1 on V8s. Ford, as always, is the odd one out.
BoxWrench V8 Engine Specs | Torque Specs - Cylinder Numbering - Firing Order - Distributor Rotation
clubairth1
30
Sep 3, 2025 04:38 PM
42Ajd
Dec 30, 2015 09:45 AM
duecedriver
Dec 25, 2015 11:47 AM
Greg Reed
Sep 11, 2015 08:41 PM
Bcrary3
Sep 11, 2015 10:36 AM
