DIY: Adding Homelink to an 03+ S-Type FAQ
Old May 10, 2014 | 04:06 AM
kosta013's Avatar
To clarify, I am assuming that you will have a replacement Overhead Console and will combine parts from your existing Console and the replacement.
Old May 11, 2014 | 06:00 AM
hatredem's Avatar
Thank you for your response.
You said that you are waiting for suitable overhead console, so if I live in Europe and I would have bought the console from US then the frequencies wouldn't match and I won't be able to programme the homelink?
Old May 11, 2014 | 07:52 AM
kosta013's Avatar
Yes, the frequencies used in Nth America are different to Europe and some other countries i.e Australia. I have heard that you can use a Nth American module in Europe but you will need to modify the frequency receiver on the garage door opener unit itself. What country are you in ?
Old May 11, 2014 | 09:03 AM
hatredem's Avatar
I'm from Poland. Is there any instruction manual how to modify the frequency? If I got it right I have to modify the frequency of the homelink module to match that in garage door remote key?
Old May 12, 2014 | 06:19 AM
kosta013's Avatar
i would first check what frequencies are used in Poland, and, I don't think you can change the frequency of the Homelink garage door opener module itself.I understand but may be wrong that Euro countries use the same frequency i.e 433MHz for garage door openers. If that is the case you should be able to use a 2nd hand module from any Euro country but you will find that the cheapest are on Ebay.co.UK. X Type modules and some other models will fit the S Type.
There are some other posts on the site that may help you and I will try and dig them up after I return home shortly.
Old May 13, 2014 | 03:39 AM
hatredem's Avatar
I've found somewhere that frequencies for nth america and europe differ so I decided to buy cheap xtype console with HL module and I'am going to try putting that module in my s-type console. Thanks for help. If I find time I will post here some photos of final configuration.
Old May 15, 2014 | 04:45 AM
kosta013's Avatar
Check out Alec's XJ Project
Old May 29, 2014 | 11:29 AM
  #28
mkontos's Avatar
Do anyone noes in what mhz is working the homelink for the US cars, and if is similar with the Europe transmitters?
Old Jun 1, 2014 | 07:04 AM
kosta013's Avatar
The frequency in the United Kingdom is 433MHz and North America 315MHz & 390MHz
Old Sep 21, 2015 | 11:11 AM
  #30
jazzwineman's Avatar
Default Don't Do IT and DO NOT EVEN TRY
This overhead console is one of the quirkiest and most ill-designed products I have ever seen. I am computer engineer and NASA certified in some areas of electronics and I have spent more time fiddling with this piece of s... for more hours than trying to rebuild an engine, It is cheaply put together, hard to manage and easy to break. Little springs and switches that if not fitted perfectly are not going to work and everything is plastic and subject to breakage. Even changing a light bulb is difficult and not as easy as putting a small screw drive or shive into it. The little metal toggles that have to be fitted tightly and from only one angle at the top make no sense and they are almost impossible to get off without bending, The flip door in front is all plastic and spring and plastic clips and subject to breakage as well.
Just leave it alone or you will have more problems than you can imagine.
I would imagine that Gus or Rick could do it along with the Jag techs, but the tech have years of experience and even they will tell you the horror stories.
Tom in Dallas
2005 S-Type 3.0 85k
Old Sep 21, 2015 | 12:28 PM
  #31
Jon89's Avatar
Hey, what else would you expect from Jaguar plastic?!
You've owned your car long enough by now to realize that two sorry factors will eventually cause the death of our vehicles: 1) the plastics and 2) the electronics....
Old Sep 21, 2015 | 01:51 PM
  #32
JagV8's Avatar
Especially after 10 years. I expect they would consider that adequate, pesky though it is.
Old Sep 21, 2015 | 01:54 PM
  #33
davidladewig's Avatar
I have not been able to get my door to work from the car either.
Old Sep 22, 2015 | 06:01 AM
  #34
kosta013's Avatar
It is a bit tricky but I know from experience you do not have to be a tech to do it. I managed it.
Old Sep 22, 2015 | 08:55 AM
  #35
It is beyond "tricky". If you start cold with it and try to make sense out of it and use normal and common logic - you are lost. Forgetting the materials issue- it is a poor poor design and you can spend several days trying to get it right.
Tom in Dallas
Old Sep 22, 2015 | 12:34 PM
  #36
tbird6's Avatar
How old is your garage door opener?
The Homelink in our S Types is getting old.
In my new house I could not get either my 2003 LS or my 2005 STR to work any of the 5 automatic door openers. I fought with this several long and frustration times.
Turns out that Homelink has been totally changed and our cars will not work with these new type garage door openers. Here is an explanation of what is going on.
https://www.facebook.com/notes/liftm...21439917914472
Just great you say??
Well here is the work around and it works fine and is pretty cheap at $25.
You need a Homelink Repeater kit.
https://secure.homelink.com/homelink...ter-kit-detail
HomeLink
You can get them on EBay and Amazon but surprisingly I found the Homelink people to be the cheapest.
What's going on is the frequency was changed. So you need this repeater kit so your remote will talk to the repeater kit. Then the repeater kit has the correct frequencies to talk to the new style door openers.
Now notice the repeater kit has a short piece of wire hanging out of it. That's an antenna. The push button remote that comes with the repeater is only used once and then it's never used again and you use your car buttons just like always.
You need one repeater kit per garage door.
Old Sep 23, 2015 | 04:56 AM
  #37
JagV8's Avatar
Pah. They ought to have at least called it HomeLink2 or some such so we had a chance to know it was changed to a new, incompatible version!! And then that there's a cheap converter.
Clare Jennings
Oct 4, 2015 05:43 PM
Jaguar Forums Editor
Jaguar Press release
Sep 28, 2015 05:18 PM
