Drain Plug
Welcome to the forum aviation14,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Welcome also.
The engine drain plug is on the RH side of the sump casting, facing the RHF wheel, and towards the rear of that sump.
It is a 13mm spanner size, and it is a bolt with an integral washer as part of the head.
If you still cant see it, post back, and I will jack mine up and take a Kodak of it for you.
Last edited by Grant Francis; Sep 8, 2014 at 09:50 PM. Reason: Spelling still sucks
Grant, thanks for the information. Though that the 22 mm plug was the transmission and was correct. Will look again. As stated the filter was easy to view and address. In a session on youtube saw that on latter models there was a plastic cover that had to be removed from the bottom of the engine.
It appears that this is not the case on the 2001 years.
Dick
Dick
Correct on the cover, so we are blessed.
The engine drain plug is in the "lowest" point of the cast alloy sump, and I reckon you will see it.
I am working AM tomorrow, so if you still have issues finding it, let me know, as I said.
aholbro1
Dec 29, 2024 06:46 PM
