driver door latch is not working from remote or from button.
i check every wire from latch to driver door module. From driver door module to general electronic module and rear electronic module - wires are good.
recently replaced the driver door module (but mot programmed) and installed new latch - same situation.
and i will tell the funny - driver side mirror doesnt working as well.
were replaced ddm 3 times. Same situation.
is there someone who can help me?
in attached image green marked are checked wires (everything was okay)
I have similar problem. Door module is replacet, remote is programed and it wont global close sunroof and the windows. After locking everythink is ok. Unlock works normali about 20 minutes after locking. After that time, i wont unlock and turn the alarm off. I can openit only with the key manuali.
Back on your problem, did you change drivers door lock? I change passenger one on mine and that solved the problem like yours.
Does the DDM need to be programmed to match the vehicle? I was thinking it is not plug and play, but am not sure.
How about ground CA30? This is the ground for the DDM, the door latch, and also mirror heat. You could test this ground by turning on the rear window heater and seeing if both side mirrors also heat up. If the driver's mirror does not get warm, ground CA30 may be at fault.
yes i changed lock, changed ddm, checked every wire and even more - opened every module and visually checked.
everything is okay but lock doesnt work.
I think you need to answer Karl's VERY important question? Did you program the DDM to your car? Does it need to be programmed to your car?
I would find the answer to those questions before doing anything else?
If you did replace the DDM 3 times with the same non working results that's telling you something?
I think programming is for remote key only.
lock wires and mirror wires are directly going to ddm and buttons are also going to ddm directly.
The fobs work from the ddm. Do you have a code reader that can read the modules. That would help a lot. Also you can read live data as you operate the individual problem areas
i have.. but its not helping. It says everything is fine.
