flat battery
Old Nov 9, 2024 | 12:34 AM
knares's Avatar
Default flat battery
i take my granddaughters to school in a morning, left the park lights on, seven hours later the battery is to flat to start the engine, key doesn't fit the boot, WHO else would put the positive terminal behind the front wheel cover
Old Nov 9, 2024 | 01:43 AM
JagV8's Avatar
You can use your other key (in the boot).
To everyone reading this:
1. make sure you have at least 2 working keys
2. at least annually check they work to open the boot (trunk)
Old Nov 9, 2024 | 03:57 PM
Peter_of_Australia's Avatar
Yes, this works, IF the key used at the moment is the valet key. If THAT is not the issue, try to spray penetration oil or graphite or WD40 into the lock at the boot first.
Just a note: I have 4 fully operational (i.e. non valet keys) for every of my Jags and I use the boot lock from time to time.
Most importantly: I keep the 2 original Jaguar keys at home, and only the 2 copies are in use, because (at least for the after 2004 S-Type) you need both original keys to be able to duplicate the transponder yourself onto the third and fourth key.... Meaning: If you loose one of the OE keys, you have a bit of a problem.
Esprit
Jan 26, 2024 03:20 PM
Crobertrod
Sep 1, 2019 09:57 AM
Petemcca
Jun 7, 2017 01:25 PM
matthew.r
Apr 12, 2012 05:29 AM
pordric
Oct 6, 2010 04:29 PM
