Dyno pull:
Old Oct 30, 2014 | 06:35 PM
Wuzupez's Avatar
Default Dyno pull:
Took the car to the dyno tonight for a few pulls! 7 to be exact! Highest it hit was 347hp and 359tq! All the other pulls were 334 to 346 horse and 342 to 359 torque. A lot better than I expected!
Attached Thumbnails Dyno pull:-image.jpg
Old Oct 30, 2014 | 06:37 PM
Mikey's Avatar
Nice!
Even with no changes made to the car it gained 13HP!
Old Oct 30, 2014 | 10:17 PM
tony1963's Avatar
What did that cost?
Old Oct 30, 2014 | 11:09 PM
1320racer's Avatar
Please repost your dyno graph so we are able to see the entire curve
  • needs to be right side up
  • need to have full view of both axis (X,Y) values
What type of dyno was used?
If you got the air fuel ratio data, where was the sensor placed?
Old Oct 31, 2014 | 03:16 AM
JagSTR2004's Avatar
Very nice numbers! Especially considering your running only mina mufflers and an intake. Need to get mine on the dyno soon and share the results.
Old Oct 31, 2014 | 11:42 AM
rasputin's Avatar
Originally Posted by 1320racer
Please repost your dyno graph so we are able to see the entire curve[*]needs to be right side up[*]need to have full view of both axis (X,Y) values What type of dyno was used? If you got the air fuel ratio data, where was the sensor placed?
Agreed and if you can repost the bottom, median, and best pulls in full. Thanks for sharing and good numbers.
Old Oct 31, 2014 | 02:58 PM
Wuzupez's Avatar
It was a dynojet Dyno.
Old Oct 31, 2014 | 03:17 PM
Wuzupez's Avatar
No clue why these are posting upside down? Sorry guys
Old May 11, 2015 | 09:16 AM
pab's Avatar
pab
Ran my S-Type on the dyno over the weekend and think it did pretty well.
My first pull was best: 250.06hp and 259.57 torque. The torque line
was pretty flat from 3.5k to 5.0 maxing at about 4.2k. HP maxed at around 5k and held pretty flat to 6k before falling off towards the shut down point that happened at around 6.4k
Dyno dude said it was running kind of rich at the end, but that that was pretty usual for factory settings (i.e., keep from going lean and "lunching" the engine).
All in all I think it was pretty good for a bone-stock 4.2l with ~60k on the clock.
That's my story and I got the numbers to prove it... ;-)
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
damienedwards
May 2, 2016 04:51 AM
Johncy2000
Sep 16, 2015 05:44 PM
SteveM
Jun 11, 2014 11:27 PM
1320racer
Sep 27, 2011 05:47 AM
