Educate me on the OLM327 please
Old Apr 19, 2011 | 07:03 PM
Blue Lion's Avatar
Default Educate me on the OLM327 please
As I posted awhile back, I recently inherited an S type from my Dad. The check engine light has been on and off. I bought an ELM327. It plugs into all 3 cars, the red light comes on, but that's it. I can't get it to recognize any ports, I've moved the USB connection to each port, and I've tried changing the ports in the ScanTool.net program.
I figure I'll get better responses here than from the seller.
I'm running XP on my laptop and the software has installed fine.
Help!
Thanks.
Old Apr 19, 2011 | 09:25 PM
Blue Lion's Avatar
Default Sorry, ULM327
Messed up the title.
Old Apr 19, 2011 | 09:32 PM
vance580's Avatar
You have to install it exactly how the directions state. If you dont follow them step by step it wont be read by the software. I did the same thing just plugged in it has it read and installed the software and it didn't work then looked at the directions and followed them and worked. So uninstall the software and start over and follow the directions and you should be good.
Old Apr 20, 2011 | 01:47 AM
JagV8's Avatar
Check in XP Device Manager that you have an extra COM port you didn't have. IIRC (but it's been a while) install is 2 stages: a USB driver then a (USB-)COM driver.
When you have the drivers, and not before, you then have to get the baud rate right. Usually 38400 but try 9600 if not.
You'll need the car's ignition on / engine running - maybe the whole time of the above, sorry can't recall.
Old Apr 20, 2011 | 06:52 PM
Blue Lion's Avatar
Are there directions somewhere online? I got a disk with the programs, and the ULM. That's it.
Thanks again.
Old Apr 20, 2011 | 07:38 PM
dbeardsl's Avatar
I had the same issue with mine.... Plus I was a dumb *** and went for the cool "Bluetooth" version, that only complicated things further.
Luckily I know just enough about computers to be dangerous, so I was able to blast my way through it. But, I admit I was stumped for a bit. Following the directions carefully was required.
I found a bunch of helpful videos on YouTube. Lots of folks with the same issues.
Old Apr 21, 2011 | 12:55 AM
JagV8's Avatar
It's an Elm - or at least I hope it is!!
google will find stuff if asked
You have looked for a readme / etc on the CD...........
Old Apr 21, 2011 | 09:12 AM
achysklic's Avatar
On the disk thatr came with it is a read me file open it and follow the instructions, also there should be a password for your elm device without this password it won't connect.
dmatthewman
Sep 30, 2015 10:10 AM
lighterthanair
Sep 24, 2015 08:36 PM
axr383
Sep 15, 2015 06:53 AM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
