electric window
Old Dec 21, 2009 | 05:40 PM
03styper120k's Avatar
Default electric window
driver power window dosnt go down automaticly anymore what did i do ??
it will go down but you have to hold button
still goes up automaticly
Old Dec 21, 2009 | 07:41 PM
Thermo's Avatar
Veteran: Navy
03Styper, try reprogramming the windows. For this, you will need to press and hold the window down button until the window reaches all the way down and then hold it for an additional 5 seconds (may be only 3). Then pull and hold the up button until the window is all the way up, holding the switch for an additional 5 seconds (again, may be only 3). That should fix your issue. If not, then odds are you have a problem with the over current circuitry that senses when the motor reaches its full travel and is stopped.
Could be also that your window motor is starting to go and it is getting weak. This can cause a higher than normal operating current. Reprogramming the window will help with this. Raise and lower both of the front windows at the same time. Is one faster than the other? If so, the slower window is the one with a motor that is starting to go.
Old Dec 21, 2009 | 10:21 PM
Toller's Avatar
I was taught to do the front windows together by holding the position for 5 seconds and to do the complete cycle (both down, wait 5, both up, wait 5) a total of 3 times. The rear windows seem to be a separate action. I suppose it could be any two or more windows that are cycled together. Dunno.
I've learned that going all the way in automatic (either direction) seems to call for a momentary press and then a second one. This may just be something I've taught myself as in....first press wasn't enough to trigger the action so I pressed it again.
Eric
Old Dec 21, 2009 | 10:59 PM
I need the double press action as well.
Old Jan 2, 2010 | 12:57 PM
Default electric windows
>Well i tried the reset feature and it works only one time
>I tried the speed test it is the same up and down speed as passenger
> I can hear a loud kerclunck when it gets to bottom ??
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
rentzoo
Nov 10, 2015 04:56 PM
frank regalado
Sep 16, 2015 06:15 AM
