Electrical Problems?
Old May 30, 2016 | 07:01 PM
Whompert's Avatar
Exclamation Electrical Problems?
05 V6 S-Type owner here, and I honestly don't know why my car won't start up, not cranking, ever since I disconnected and reconnected the battery. The voltage on the battery reads 12.1v, basically a brand new battery too (about 2 weeks), and I've tried jumping to no avail. Some other problems I experienced before disconnecting is a parkbrake fault, and my a/c system screen glitching up until not even turning on at all, and my key fob not working, and I'm pretty sure its battery is okay.
I'm pretty new to Jaguars so I would greatly appreciate if any of you knowledgeable could help me out.
Old May 30, 2016 | 11:11 PM
NBCat's Avatar
If the battery has less than 12.2 volts with the ignition in the off position and the headlamps on, the battery is suspect, regardless of age.
What is the number of kilometres/miles on the vehicle?
What is the fuel pressure at the Schrader fitting on the injector rail?
Is the MIL on, and if so, what codes are stored in the system?
Old Jun 1, 2016 | 08:00 PM
Gus's Avatar
Gus
Have you attempted to start the car in “N”? See if this helps.
Old Jun 2, 2016 | 01:17 AM
JagV8's Avatar
12.1 is very low. Maybe it will recover if charged else need a new battery.
klintous
Apr 15, 2022 10:44 PM
rmiklosh
Jun 9, 2016 12:38 AM
dennyhle
May 25, 2016 09:21 PM
revski666
May 13, 2016 01:34 PM
mksxjs
May 11, 2016 10:03 PM
