ely blanly Blank Message Center
Old Jan 20, 2008 | 11:04 AM
FactoryJaguarTech's Avatar
Default RE: ely blanly Blank Message Center
2000-2002 S-Types were pretty bad for having IPK failure.
Not going to be much you can do about it.
You may want to pull the pack out and check the connections are good. But I hate to say it, your pack it probably going bad.
The worst part is, it is not a plug and play item. You will have to get it programmed if you replace it. Key codes go through the IPK so it will not start until programmed.
Old Jan 21, 2008 | 04:41 PM
jag_genius's Avatar
yep that will set you back over a $1200.. some people just drive with out the odometer working..
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
leep123
Sep 30, 2015 03:41 PM
42Ajd
Sep 26, 2015 07:04 PM
aadjei
Sep 25, 2015 03:07 PM
