epb problems
Old Apr 25, 2017 | 12:57 PM
cjbanuelos's Avatar
Default epb problems
iafter changing my rear brake pads an rotors on a 03 s typev6 my parkbrake fault light came on how do i fix it. nervous to even move it
Old Apr 25, 2017 | 01:14 PM
JagV8's Avatar
Did you leave the key in and/or anything switched on - could then be a flattish battery (in which case charge it).
You can reset the EPB - essentially remove its power (or the car battery) and you should be prompted what to do. Very easy and can be done any time.
Old Apr 25, 2017 | 01:19 PM
BlackKat's Avatar
Remove key. Remove the rear tires and manually pull the EPB lever for each wheel until it is fully engaged.
Turn key on then apply the EPB to set.
Old Apr 25, 2017 | 01:41 PM
Mikey's Avatar
The EPB reset procedure has been published here probably half a dozen times. Takes 2-3 minutes to accomplish all from the comfort of the drivers seat.
Digital Will
Feb 21, 2026 05:58 PM
wendelllambert
Apr 25, 2017 07:20 PM
IIIMik3
F-Pace (X761) / C-X17
Nov 21, 2016 06:41 AM
hakunti
Oct 22, 2016 08:09 AM
XJ40 ( XJ81 )
Oct 27, 2006 01:02 AM
