Expansion valve or compressor??
Old Jun 19, 2009 | 02:55 PM
scottyj2's Avatar
Question Expansion valve or compressor??
I have a 2003 S-Type and the problem is that the A/C stops cooling when the car comes to a stop but otherwise cools OK engine RPM above 1500. Cooling fan is working, stuck a piece of paper in frt of condenser and the vacuum sucked it to the condenser face. Compressor is running NOT cycling continuosly with control set to LO+Recirculate. Low side reading is 85-90/ highside is 200-210. A fresh recharge has just been done 750grams(1.7lbs.) with Correct oil(under 2oz)injected. Is a stuck open expansion valve the likely culprit or is the compressor weakened. Any one have diagnostic tips? It is my wifes Primary car but I sure love driving her. Help please !!!!
Old Jun 19, 2009 | 03:00 PM
searanch's Avatar
Wink
This is primarily a Jaguar enthusiasts forum but if you insist on a little "Dr. Phil" I'm sure someone will be happy to oblige...
Old Jun 19, 2009 | 03:03 PM
scottyj2's Avatar
Good Point . I meant our Beloved Jag no pun intended. Any tips?
Old Jun 19, 2009 | 03:30 PM
ken@britishparts.com's Avatar
My guess would be the expansion valve. The high side seems about right, so I would assume the compressor is fine. Don't forget the drier!
Old Jun 19, 2009 | 08:38 PM
scottyj2's Avatar
I also noticed tonight that there is no condensation draining.
Old Jun 20, 2009 | 06:09 PM
scottyj2's Avatar
Does anyone Know if the Evaporator threads into the Expansion valve or is the valve made onto the evaporator solidly? Are there any gaskets /O-rings that I need to get seperately to replace Expansion Valve? Ex. Heater Case Gasket, Case to Firewall?
04Xjrsteve
May 7, 2019 04:06 PM
vwbusbits
Oct 13, 2015 03:43 AM
Jaguar Forums Editor
Jaguar Press release
Sep 28, 2015 05:18 PM
jjmiah217
Sep 28, 2015 09:09 AM
