Factory Brake Pads / Who Built the Stereo Unit?
Old Mar 26, 2009 | 08:15 AM
Jon89's Avatar
Default Factory Brake Pads / Who Built the Stereo Unit?
2005 S-Type 3.0 that just turned 24,000 miles.
Are the factory pads designed to start "chirping" just prior to reaching their end-of-life?
My front pads look like they might make it to 30,000 miles, but maybe not. My rear pads look great, probably not even close to halfway used up yet.
I know these factory pads typically don't last very long, so an automatic "chirping" pad design would be great.
Also, who built my single-CD audio system? Is it an Alpine unit? Are the speakers also Alpine? For a factory-installed system, I'm happy with its performance thus far.
As always, thanks for your assistance....
Old Mar 26, 2009 | 08:48 AM
ken@britishparts.com's Avatar
No special design on the brake pads. They just wear out.
The radio was built by a guy named Hans.
Old Mar 26, 2009 | 08:50 AM
Jon89's Avatar
Very funny, Ken.
Any idea who Hans works for?
Old Mar 26, 2009 | 08:58 AM
carelm's Avatar
Hi Ken,
What happened if Hans went on vacation? I could see the entire S-Type production line coming to a screeching halt without his valuable services.
On another note, does your company offer air and oil filters for the S-Type 3.0 engines? The website indicates a 4.2 V8 application only.
Thanks,
Mike
Old Mar 26, 2009 | 09:43 AM
Glad you saw the humor!!! That damn Hans! (Obviously, I don't know much about the entertainment systems.)
Yep, the V6 filters are here:
http://www.motorcarsltd.com/item.wws?sku=IN104801
That's the after market and the factory aren't that much more expensive:
http://www.motorcarsltd.com/item.wws?sku=IN104659
Air filter is cheap, too:
http://www.motorcarsltd.com/item.wws?sku=IN104812
Old Mar 26, 2009 | 10:02 AM
Brutal's Avatar
Pads need to be replaced when you hear grinding, then you can buy rotors too......
I can see where this thread gonna go now....
Old Mar 26, 2009 | 10:27 AM
carelm's Avatar
Thanks Ken,
It's almost time for me to do the spring ritual of filter changes, oil changes and brushing up on my cursing when I try to swap out the pollen filter.
I would imagine when and if, the time comes for me to swap out my ignition coils, I will need at least a 12 pack (preferably a dark ale) and hopefully, not disturbing my neighbors with my foul language.
Mike
Old Mar 26, 2009 | 10:31 AM
Sounds like you've got the right attitude.
Listen to Brutal or Jag Genius on the radio stuff. These guys really know what's going on.
Old Mar 26, 2009 | 11:19 AM
Brutal's Avatar
Originally Posted by ken@britishparts.com
sounds like you've got the right attitude.
Listen to brutal or jag genius on the radio stuff. These guys really know what's going on.
speaking of knowing whats going on ...ken any luck on the inner door handle?
Old Mar 26, 2009 | 12:33 PM
Brutal, I've struck out on used. I've got plenty of them with the cable broken off.
Old Mar 26, 2009 | 12:45 PM
Brutal's Avatar
brutal, i've struck out on used. I've got plenty of them with the cable broken off.
how much, cause the cables fine on this one but the handle pin is broke
Old Mar 26, 2009 | 12:47 PM
I'll find out and give you a call.
Old Mar 26, 2009 | 04:04 PM
joycesjag's Avatar
Is that grind like a dry hump or more like a wet sloppy grind?
Old Mar 27, 2009 | 05:30 AM
JOsworth's Avatar
Mine didn't grind at all, they just did the shimmy, shimmy shake. I feel ripped off somehow!
Old Mar 27, 2009 | 07:31 PM
joycesjag's Avatar
shimmy, shimmy shake? I thought it was more like shimmy shimmy coco pop. (fer' all you youngsters out here it was a 1950's song)
H20boy
Dec 24, 2024 03:23 PM
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
Dz1rfj
Sep 16, 2015 03:44 PM
JagLove86
Sep 6, 2015 10:36 PM
