Fault code PO174,171- Can't find the problem!
Old Nov 20, 2012 | 04:11 PM
  #61
Simon.h's Avatar
Originally Posted by Brutal
alright then try this one on for size
i had a 2011 xj 5litre that was over heating and seemed to loose coolant under the intake. I pressure tested it several times and held pressure to 15 psi everytime so i decided to vacuum the system. And low and behold itsucked air big time, you could see it coming into the coolant reservoir and hear it too. It was coming from the outlet pipe under the intake. Would hold pressure and had minimal coolant loss. But as the engine cooled down it sucked air into the system and created a air lock and then would overheat. New pipe and all fixed.. The moral. Just because it didnt leak under pressure doesnt meen it doesnt leak. Remember it runs under vacuum not pressure unless boosted and then only when rpm is up. Again if it were me, ide look at short term fuel trims and spray potential areas. And even do it when cold and seals are at their smallest and more prone to leaking
one other thing I just noticed, youre dual fuel and I dont know that system, I can only speak from gasoline system experiance on Jaguars since thats what we have here in the US
Cheers, but it also happens at low revs at 20mph. Also does it on petrol and then on gas/lpg. My fuel trims are around 5% at ide .
Old Nov 20, 2012 | 04:29 PM
  #62
Brutal's Avatar
Where are they when rpm increases and vacuum goes down?
Old Nov 20, 2012 | 04:55 PM
  #63
Simon.h's Avatar
I can't remember, so I will recheck tomorrow and come back to you.
Thanks for your help on this.
Old Nov 20, 2012 | 05:52 PM
  #64
JagV8's Avatar
Yes. See my post #44. No idea why I typed it.
Old Nov 23, 2012 | 09:46 AM
  #65
Simon.h's Avatar
Heres the long term fuel trims-
Bank 1 long term- ide 7.34%, fast ide 2500rpm 4.69%, driving 17.97%
Bank 2 long term- ide 7.81%, fast ide 2500rpm 4.69%, driving 17.19%
I also took readings from my other car (for comparison) MG ZT V6-
Bank 1 long term- ide 0.94%, fast ide 2500rpm 7.03%, driving 17.83%
bank 2 long term- ide 17.19%, fast ide 2500rpm 7.03%, driving 23.76%
For USA members who do not know what this car is-
Attached Thumbnails Fault code PO174,171- Can't find the problem!-mgzt190-016.jpg
Old Nov 23, 2012 | 10:51 AM
  #66
JagV8's Avatar
Your ZT has a problem on bank 2, probably an air leak.
Not sure on the jag but looks like a leak when under vacuum. Both banks so you'd be looking for places they have in common. Try propane if you fancy it...
Old Nov 23, 2012 | 11:44 AM
  #67
Simon.h's Avatar
I had a feeling someone was going to say that about my ZT!
So you still think i have a leak on the jag, well as i done both the lower and upper inlet to heads gaskets and both IMT o rings and checked vacuum/breather pipes about 5 times and done a smoke test, i do not where to start (do not fancy propane).
And i as need to look at the ZT as well.
Thanks Simon.
Old Nov 23, 2012 | 02:03 PM
  #68
Gus's Avatar
Gus
Check the vacuum line to the brake.
Old Nov 25, 2012 | 02:26 AM
  #69
Simon.h's Avatar
I have been over it again, did a smoke test for 30mins and sprayed carb cleaner all all it and the only thing i found was a oil leak (air leak then doing a smoke test) from the cam sensor.
This sensor screws into the top of the head and rocker cover sits over it, could this be my problem?
Anyone know how to change the seal? Please do not say the inlet manifold/cam cover has to come off.
Picture copyed from one of Jojcesjag's posts, sorry.
Old Nov 25, 2012 | 05:03 AM
  #70
Simon.h's Avatar
Sorry, its a variable camshalf timing control soleniod sensor.
Old Nov 25, 2012 | 06:56 AM
  #71
joycesjag's Avatar
Simon no worries on the pic.
I cannot recall if the valve cover needs to be removed to switch out the seal. What I would do is obtain a new seal, then try to remove the old seal, almost looks like it maybe possible to replace without removing the valve cover. I just looked at Joyces Jags and a screwdriver with a few slight pounds of a hammer may pop it out.
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
rudelover2
Sep 11, 2015 08:53 PM
NinoGrimace
Aug 26, 2015 05:15 AM
