Fitting CATS shock absorbers
Old Nov 25, 2012 | 05:25 AM
Fermanaghman's Avatar
Default Fitting CATS shock absorbers
I have "standard" shock absorbers on my Year 2000 S type. Was thinking of replacing them with a set of s/hand CATS I have been offered. Is it feasible and if so, is there a lot of work involved with the "conversion" ? Thanks.
Old Nov 25, 2012 | 07:38 AM
bfsgross's Avatar
Not sure this can be done. Your S must have the wiring, module, etc. Let's see what others have to say.
Old Nov 25, 2012 | 07:44 AM
plums's Avatar
You need to consider the control circuitry.
However, you can always run them in manual mode with a switch and relay.
Old Nov 25, 2012 | 08:54 AM
JagV8's Avatar
I think the module uses the accelerometer (*) and other data to control each of the 4 individually so that would be 4 switches and 4 relays.
(*) they won't be fitted to your model
This may be more work than it's worth.
Old Nov 25, 2012 | 09:42 AM
abonano's Avatar
I don't believe CATS can be properly fitted into a Non-CATS fitted S Type. As the other forum members have already pointed out above - way too much involved with wiring, module, sensors, etc...
1LowCat
Sep 14, 2015 07:51 PM
Safari
Sep 14, 2015 10:29 AM
KarimPA
Sep 12, 2015 08:15 AM
EZDriver
Sep 8, 2015 09:25 AM
Busa R
Sep 3, 2015 05:01 PM
