Finally adjustable rear camber
Old Apr 5, 2025 | 10:22 PM
Mecca148's Avatar
Default Finally adjustable rear camber
So as you all know the s type from factory has non adjustable rear camber. And for the type R owners that can mean some serious inner tire wear especially if you are running soft compound tires.
but I finally came across a website that sold them for the Lincoln LS, so I opted to buy a pair to test out for the s type, and they fit perfectly.
https://www.stukellymotorsports.com/products/lincoln-ls-adjustable-rear-upper-control-arms-with-replaceable-bushings-set
the only minor issue is that will need to zip tie or drill and bolt the leveling arm to the new control arm somehow.
but I am finally running 0 camber in the rear(originally-2). I was going to through soft compound tires once a year due to inner tire wear especially and this should be the cure!
Old Apr 6, 2025 | 03:48 AM
Sportston's Avatar
That looks great! Would love a pair like that on mine. You might want to get some boots to cover your rose-joints to avoid premature wear.
Old Apr 6, 2025 | 06:10 AM
clubairth1's Avatar
Community Influencer
Hey great find!
Too bad they are steel compared to the lighter Aluminum arms.
Old Apr 6, 2025 | 06:17 AM
Mecca148's Avatar
They weigh just about the same as the oem part, but I’m pretty sure they will be stronger than the cast aluminum part.
gozoom
Mar 31, 2019 09:45 AM
PunisherFType
Nov 13, 2017 07:53 PM
LnrB
Oct 31, 2015 04:19 PM
StrateLoss
Dec 29, 2009 03:48 PM
gdrag
Aug 20, 2009 07:53 AM
