S-Type 2008 Forgets both keys
Mans, hello everyone! About an hour after locking the car with the central lock with the key, when you return, the central lock stops working. You open the door with a dummy, the car screams, you insert the key into the ignition and everything is fine and the central lock works again and so on in a circle.
If you open and close it within 20 minutes, everything works. No errors! I will be grateful for any hint! Thank you!
That's a tough one for sure. No codes either.
Have you tried the car reset in SDD? I have not used this yet but it was suggested to me on another thread with no clear answer to the cars problems. Not sure if it's under recommendations or extras?
So, I haven’t gotten to it yet, I saw in the diagram that there is another block at the back, couldn’t it be there?
DDM,Can it be simply replaced with another one and that's it? All grounding is in order, I repaired and looked at all grounding a year ago. Sometimes the rear right door does not open.
GeorgesJag
Jul 7, 2014 05:12 AM
