Fluid Question
Old Jun 8, 2013 | 11:17 AM
jazzwineman's Avatar
Default Fluid Question
Is the power steering fluid in the S-types a synthetic or mineral oil based type. Would the "Pentosin - Hydraulic System Fluid" fit the bill or what have people used and is considered acceptable?
Tom in Dallas
2005 S-Type 3.0 66k
Old Jun 8, 2013 | 11:45 AM
Dexron III is the specified fluid
Old Jun 8, 2013 | 09:33 PM
I would not use that Pentosin fluid.
OK, it is probably suitable, and a lot of the "Aftermarket" oil companies are upgrading their product specs constantly to get more of the "owner service market" $$, BUT, I work in that industry, and the catalogues are soooooo wrong it is scary. Then add the scenario that if something goes AWOL, YOU foot the bill to put it write.
I run Synthetic Dex in all the Jags, in the steer and trans. I also use it in other owners Jags I care for at home. Synthetic oils are a direct use for mineral, and will mix without any issues. The only exception here is brake fluid, so I am told.
Old Jun 9, 2013 | 12:01 AM
That was why I was asking. That does answer my question.
Tom in Dallas
Old Jun 9, 2013 | 09:21 PM
motorcarman's Avatar
The only S-Type that had a special fluid was the 2000MY introduction year that had the Ford rack (ESSO 998). It also required a vacuum devise to bleed air from the system. The ZF rack in later years was self bleeding and used normal Dexron as stated.
Pentosin 11S is good for the hydraulic top reservoir in the X100 conv. or Audi/VW steering systems.
bob gauff
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
abonano
25
Sep 25, 2015 10:43 AM
kstevusa
Sep 7, 2015 01:12 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
