Fuel Trims
Old Mar 25, 2018 | 04:52 PM
ZenFly's Avatar
Default Fuel Trims
My iCarsoft short term fuel trims are + or -- numbers like 1.76 to high 3.14 alternating to 0.0 then to fast changing numbers above and below zero. Long term trims are similar numbers but don't change fast.. From what I understand of it I think these numbers are OK..
Old Mar 25, 2018 | 05:02 PM
JagV8's Avatar
Depends when you look - hot engine at idle is best to start with.
So long as the STFTs are small (*) you can then ignore them and care about LTFTs.
(*) i.e. any larger values have migrated into the LTFTs, call that learning by all means
Old Mar 26, 2018 | 02:59 PM
leaping cat's Avatar
I would select to monitor only these trims and watch them in graphical mode.
What you should see is a sinus curve.
Old Mar 28, 2018 | 06:35 AM
JagV8's Avatar
Not true on his car.
H20boy
General Tech Help
32
Dec 8, 2019 09:18 AM
MoscowLeaper
Sep 24, 2013 11:37 PM
cpm53
Dec 21, 2012 02:59 AM
The Coupe
Mar 20, 2012 08:37 AM
smitty5534
Aug 18, 2011 08:22 PM
