Fule pump problem
Old Jun 28, 2010 | 10:00 PM
David Type S 01's Avatar
Default Fule pump problem
OK guys Plz help me out .. I had my car a 01 type-S running in my yard and it ran out of gas. So I disconnected the battery because I was having some power problems.. Well when i went and got gas filled up the car wont start it crank but does start...? I check all the fused and nothing was wrong.. I check the fuel pump that good I even changed the key got a new one with a new chip that didn't work.. I also check the cut off switch that fine and the anti theft light is not on so... I dont know why my car wont start.. I gave direct power to the pump and it start up just fine so can anyone help me ??
Old Jun 29, 2010 | 12:05 AM
TopHatChef's Avatar
I'd ask everyone in the S-Type section. If I could help, I would, but I can't.
Old Jun 29, 2010 | 06:40 PM
Thank Im at Aw with this I dont no what going on
Old Jun 29, 2010 | 10:53 PM
bfsgross's Avatar
Dave, you mentioned direct power to the fuel pump started her? Ok, disconnect the battery again and touch the negative terminal to the positive for 10 seconds, leave off for one hour then reconnect and start her up while holding the pedal to the floor while cranking. Check back.
Old Jul 1, 2010 | 11:32 AM
??The negative terminal to the positive for 10 seconds?? what does that do ?
Old Jul 1, 2010 | 11:38 AM
ohh you mean the Negative from the car and the positive from the car..lol I was thinking you wanted me to touch the negative from the car to the positive on the battery
Old Jul 1, 2010 | 11:42 AM
H20boy's Avatar
the process above by bfsgross is a hard reboot procedure to clear all computer module memory. (disconnect negative terminal - car's ground, touch and hold to positive terminal of the battery for 5-10 secs) trust us, its safe
Since you ran your car dry, I'd also turn the key to the 'on' position, let the fuel pump run to fill the lines, maybe a couple minutes, before trying to crank it. The car can't instantly get fuel. That is also assuming your fuel pump is working correctly and can run.
Put more gas into it, a couple gallons may not be enough to get it all to the front of the engine. I'd fill it to 1/4 tank, at least.
And please, in the future, don't let it run out again; these cars do not like to be run out of fuel.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
