Gas smell inside cab. .
Old Feb 5, 2026 | 02:44 PM
ZenFly's Avatar
Default Gas smell inside cab. .
After fill up had a strong gas smell inside while driving away . Didn't over fill , stopped when the hose shut off. It's happened a few times before but this time was so bad I'm here for help. Stopped in a mile or so with no smell in trunk or under hood .
Old Feb 5, 2026 | 09:36 PM
kr98664's Avatar
Take a look at this recent thread, with details about the tank seals:
https://www.jaguarforums.com/forum/s...l-tank-294480/
It's easy enough to check. Lift up the bottom of the rear seat. There are two latches at the front to release the seat bottom. You will then see two big rubber plugs for the access holes through the body. Pop them off to see the tank underneath. I suspect you will see evidence of a leak at one of the caps on the tank. I also bet you will find at least one of the rubber plugs loose, as normally they keep fumes out of the cabin if the tank is leaking.
Old Feb 6, 2026 | 04:59 AM
ZenFly's Avatar
Thank you much .
Old Feb 6, 2026 | 05:45 PM
scottjh9's Avatar
If you can determine if the smell radiates back to front or vice versa then karls idea takes care of rear and front would be coming thru fresh air vent where filter is located picking up fumes from underhood. I believe the charcoal cannister is rearward under the car also. If the valve goes wonky it will release fumes to atmosphere. Also if it is getting clogged or used up. It definitely seems tied into a fillup where fumes are purged to make room for liquid
Old Feb 7, 2026 | 06:40 AM
ZenFly's Avatar
Something else to check on ... thank you too.
Old Feb 11, 2026 | 11:47 AM
jakesdad's Avatar
so...I'm the one who started the referenced thread. I still have not resolved it because I need to get the clamp ring off. What would really help me is if anyone can describe the cap itself under the clamp ring....is it just pressed down into the top of tank with the green o-ring somehow sealing it, and then the clamp ring secures the cap to the tank? I need to 1. get a new clamp ring and o-ring, then 2. figure out how to remove the old clamp ring with worm gear.
Old Feb 11, 2026 | 04:46 PM
DoubleChevron's Avatar
If you post a picture of what you are looking at, we might be able to offer some suggestions (It appears no-one has been here before).
Speedball
Jul 25, 2024 07:04 AM
04xtype04
Nov 30, 2013 04:46 PM
Clamdigger
Nov 13, 2013 02:32 PM
chazaroo
Nov 1, 2009 01:40 PM
