Gear Shifter Locked-up
Old Apr 3, 2008 | 05:01 PM
ken@britishparts.com's Avatar
Default RE: Gear Shifter Locked-up
The bolt thing is new. Good think when you scooped it up! The early models would stick in park and folks would force them and break the gear shift assembly.
Old Apr 3, 2008 | 06:57 PM
jag_genius's Avatar
the bolts were not tightened to spec from the factory.. just need to tighten the bolts and make sure the cable is adjusted properly.. all parts light up correctly.. happens on the xj's as well.
Old Apr 11, 2008 | 11:59 PM
snooktarpon's Avatar
My 2000 S-type occasionally decides to not what to leave the park position as Ken mentioned. I'm able to force it out of park but I don't like doing that (but what choice do I have). What is the proper procedure for this? Is there a fix?
Old Apr 12, 2008 | 09:26 AM
FactoryJaguarTech's Avatar
Snook your problem is different. The ramp on the parking pawl is too agreesive. There is a tsb to fix that. Takes about 4 hours and some replacement parts in the trans.
2003 on S and 2004 on XJ have the same problem as Genius said. The fix is to locktight the bolt back in. We have 3 or 4 a week. Easy fix.
Old Apr 12, 2008 | 11:55 AM
FJT, can you provide a link to the TSB? Are the costs for TSB work covered by the dealer?
Old Apr 12, 2008 | 12:33 PM
Snook PM me the last six of your VIN and also a good email address.
Old Apr 13, 2008 | 09:41 AM
jag_genius's Avatar
or just put your parking brake up .. before you put it in park..
Old Apr 13, 2008 | 09:55 AM
LOL
Old Apr 13, 2008 | 12:52 PM
conipc's Avatar
I'd love to know the location of that small bolt to do a little preventive lock-tighting....If there's a drawing, description,or TSB, could it go to conipc@aol.com?
TIA
Old Apr 13, 2008 | 01:46 PM
If you look under the car, follow shift cable. You will see where it connects to trans selector and also 2 8mm bolts that hold cable to trans. Those are the bolts. Be very careful to not overtighten. A little locktite and put them back in.
Old Apr 14, 2008 | 07:17 PM
ORIGINAL: Stack
I experience the locked shifter and have been able to correct it with applying the parking brake before shifting into park as my driveway is on an incline. However when I shift from reverse to drive I experience a slight hesitation and slight jerking motion (if my foot is on the accelerator)prior to the vehicle moving forward, and onlywhen making the initial shift(from park or reverse) to drive.
Can this be corrected by the bolt tightening suggested earlier, the gear shiftassembly fix (which Iam told runs about $1,200) or is this another problem altogether?
Stack,
there is a transmission adaption clear procedure. I will try and post it tomorrow. Easy to do yourself. It will cure the delay putting it into gear....assuming you have a 2000-2002 S.
Old Apr 15, 2008 | 10:21 AM
bigdreams05's Avatar
uh uh uh..... can't wait to see it. Mine does the same thing.
Old Apr 16, 2008 | 12:10 PM
BUMP!
Old Apr 16, 2008 | 07:12 PM
Sorry guys.....someone PM me tomorrow and remind me of this during the day. Get so busy sometimes I lose track of what I am supposd to be doing.
