Glitch in the transmission matrix
Old Nov 20, 2024 | 12:49 PM
Mark McDonald's Avatar
Question Glitch in the transmission matrix
My 2002 S-Type that is slowly getting fixed, has now resolved engine and exhaust issues. The mechanic says I still need a transmission but I can drive it around town just fine.
Yesterday I took it out in the road for a 10-mile trip. On the way out, I could get up to 60 mph and the tachometer was showing 4000 rpm. I expected that. But on the way back after an 1.5 hour meeting, I was able to go at 70 mph and the tachometer was well below 3000 rpm, essentially in normal highway range.
So what is going on with this transmission if it doesn't go into high gear sometimes but seems to be fine if it is warmed up?
Old Nov 20, 2024 | 01:21 PM
Jag_Willi's Avatar
Hello,
The problem is clear: the gearbox is not shifting every time. Have you checked the oil level? Has the gearbox control been reset?
Greetings, Willi
Old Nov 28, 2024 | 02:43 PM
Thanks for your input.
Since I am in a place where no mechanics will work on Jaguars, I'm pretty much on my own, and need instructions. How do I check the oil levels and how do I reset the gearbox control?
Old Nov 28, 2024 | 03:05 PM
motorcarman's Avatar
The gearbox is a 5R55N Ford and is also used in the Lincoln LS.
Find someone that will work on an early Lincoln LS with the ford gearbox and have them check the level.
Old Nov 28, 2024 | 03:21 PM
Jag_Willi's Avatar
There are instructions on changing the gearbox oil at JagRepair.com - Jaguar Repair Information Resource. This includes checking the oil level.
A WDS or IDS is required to reset the transmission. I don't know whether another diagnostic device such as ICarsoft LR works for resetting. If only oil is missing, then you don't need to do a reset. However, after more than 20 years, you might as well change the transmission oil.
Regards, Willi
Topkek69
May 31, 2022 05:48 PM
Xtypehaxor
Dec 17, 2021 02:32 PM
laguillotine
Aug 2, 2020 02:01 AM
chrisp1981
Sep 6, 2014 02:47 AM
