Handbrake fault
Old Jul 11, 2023 | 11:20 PM
Pohara's Avatar
Default Handbrake fault
Handbrake fault showing and the wheel sensor is fine but I'm wondering if my rear piston is partially seized on that side rear brake ? I'm waiting on the repair kit but I'm sure it's not working correctly. Anybody had this before ? The hand brake works well so I don't know for sure.
Old Jul 12, 2023 | 03:09 AM
JagV8's Avatar
You might do well to read the codes from the module. Tool like IDS/SDD or iCarSoft.
Old Jul 12, 2023 | 10:28 AM
kr98664's Avatar
Have a look here for this common message:
https://www.jaguarforums.com/forum/s...attery-193787/
Old Jul 12, 2023 | 02:56 PM
Pohara's Avatar
I have a decent enough computer but how good I'm not sure
Old Jul 18, 2023 | 04:45 PM
Pohara's Avatar
New battery going in today, only getting 11 volts before start up but charging at 15 volts .I'll post and let you know if it puts my warning lights out for the handbrake and sensor . This battery is 38 months old but I had 40 month garentee.
Old Jul 18, 2023 | 09:31 PM
kr98664's Avatar
Originally Posted by Pohara
New battery going in today, only getting 11 volts before start up...
Sounds like you are hot on the trail. 11 volts is very low. Fingers crossed a new battery takes care of it. Keep us posted.
Old Jul 19, 2023 | 01:38 AM
JagV8's Avatar
Charge the new one fully before fitting
Old Jul 24, 2023 | 03:17 PM
Pohara's Avatar
Okay charged new battery overnight and showed 13 . 8 volts .no change with car though ! Shows 12.6 volts in normal use and charges at 15 volts .dosnt loose overnight or when standing. Going to check out wiring next motor for handbrake sounds a bit harsh so may be the culprit but does work.
Old Jul 25, 2023 | 09:02 AM
clubairth1's Avatar
Community Influencer
You can but the you need to get the codes?
Otherwise you don't know where to start or what to do?
Good job replacing the battery as that is a real common problem. So you have eliminated that.
Old Jul 25, 2023 | 02:14 PM
Pohara's Avatar
I have a decent code reader and the only thing is the "hand brake fault " showing. Unplugging the module used to remove the warning for a few hours after plugging it back in but that doesn't work anymore !
I checked one side caliper was free and working well but I need to check the other side.
Old Jul 26, 2023 | 07:44 AM
clubairth1's Avatar
Can you post the code or codes?
Or do you have the handbrake error on the dash?
Old Jul 26, 2023 | 02:40 PM
Pohara's Avatar
Only the dash message showing "handbrake fault "
computer shows no codes for that.
Old Jul 26, 2023 | 02:42 PM
Pohara's Avatar
I've checked and renewed seal on one caliper with no change..I'll do the other when my health allows.
giandanielxk8
Aug 9, 2021 05:02 PM
romroc
Aug 16, 2020 09:10 AM
cincinnati
85
Jul 31, 2018 10:47 PM
collector
Jun 17, 2015 12:23 PM
Walter Brooks
19
Dec 29, 2013 08:38 AM
