The headache continues...see images
Old May 24, 2012 | 03:51 PM
Leonard_85's Avatar
Default The headache continues...see images
Taken a break from Jaguar duties.
To recap...
The Cat is back at the garage in the hope we can eliminate the poor circuit to a) Get cluster warning lamp and mileage working again
b) Get comms line to work and pull codes (currently all 9 ECUs are displaying ERR)
c)Smile again
Can anyone point out this connector block...and its duties (see images)
Thanks to previous shoddy fitting of windscreen - water has been leaking directly onto this area...
It is right behind the engine block in the central position (see images).
Attached Thumbnails The headache continues...see images-image0269.jpg   The headache continues...see images-image0271.jpg
Old May 25, 2012 | 04:58 AM
JagV8's Avatar
Car details? Best put in your signature in your user details:
Old May 25, 2012 | 12:12 PM
Leonard_85's Avatar
Sorry of course...
2000 3.0 S-Type.
I haven't a clue where the PCM is or what the connector does..
Old May 25, 2012 | 12:46 PM
tbird6's Avatar
The PCM is on the RH side behind the firewall. If you have changed the cabin filter it is directly below that on the inside of the car.
Old May 26, 2012 | 02:28 PM
Leonard_85's Avatar
And is it easy to access?
Car isn't here at the moment so can't check.
Old May 26, 2012 | 03:06 PM
clubairth1's Avatar
Community Influencer
Leonard_85;
I maybe giving you some bad information. I just saw your in England. Is the cabin filter on the right or left hand side of your car?
Old May 27, 2012 | 02:42 PM
Leonard_85's Avatar
Thanks for your concern mate.
Just found this though so no problems.
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Old May 27, 2012 | 03:07 PM
JagV8's Avatar
It's a (small) part of JTIS....
Old May 29, 2012 | 05:23 AM
Amadauss's Avatar
Looking at your pictures, I would definitely clean up that plastic on the first pic. Mine looks brand new. I use something from turtle wax called wet and black to keep it looking new. Might sound crazy but just like your skin needing moisturizer to keep it from showing signs of wear I apply this to all the rubber and plastic parts of the car especially around the doors and the trunk and hood and all looks like I just installed it. Also, if you look at your windshield glass where it touches and locks into the rubber at the bottom above the engine, it was suggested to me to run a small bead of silicone there to prevent water from going up and under and around to get into the engine area. Might again sound crazy but I did it and to date no issues caused by water.
Old May 30, 2012 | 04:34 PM
Leonard_85's Avatar
Thanks for your concern for The Welfare of Polypropylene.
However, i'm more concerned with finding the electronic gremlin which is playing havoc with the PCM and deciding to totally ignore diagnostic equipment.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
n8ertot
Oct 11, 2015 02:28 PM
Sonnyblack
Oct 4, 2015 05:42 PM
millertic
Sep 30, 2015 08:11 PM
caldoofy
Sep 28, 2015 08:43 PM
