heat entering interior from under dash
Old Apr 11, 2012 | 03:10 AM
collins23's Avatar
Default heat entering interior from under dash
I drive the 2001 s-type 3litre v6.
when i start the car is the morning,, its normal temperature inside. ( no AC )
However, after driving for a while ,when the engine starts to heat up. ( against normal engine temperature ) the heat sips in from under the dash board to the driver & co-drivers legs. The heats increases as the car is driven for longer. ( even when windows are down ).
what could be causing this ?
as a side note: ( another issue )
Been told by mechanic that power steering pressure switch was causing oil leak and needs to be replaced. would this cause the a fore mentioned problem ?
H20boy
Dec 24, 2024 03:23 PM
St.Regis
Oct 4, 2024 12:07 PM
kevinl
Oct 31, 2019 06:15 PM
John Fox
Sep 12, 2015 12:20 PM
1964Daimler
Sep 9, 2015 11:28 AM
