Heater
Old Mar 12, 2022 | 05:22 PM
  #41
Aarcuda's Avatar
Originally Posted by knares
i have looked for it, cant find it
here you go
https://www.jaguarforums.com/forum/s...3/#post2109831
Old Mar 13, 2022 | 06:24 AM
  #42
knares's Avatar
thanks, the pictures make it look easy and simple
Old Sep 27, 2022 | 03:12 AM
  #43
Downey's Avatar
Thank you for all the information. I just bought a STR and it blows hot. I’ll work through the steps layers out and see if I can fix it. And add add some fuses to the control board to prevent the kind of burn outs I don’t want.
Old Oct 1, 2022 | 09:08 AM
  #44
knares's Avatar
this is the part i was asking if i could replace with one from a later year, say 2005/6
well it took a while but its winter so thats ok
first time i tried to kix it, it didnt work, now i have had an other go and it works, no hot when on cool
now i need to fix the air con which has me confused, it dosnt seem to have a leak, or i cant find one, when i gas it, the low side is reading 100psi and the high side is reading 120 psi, it works a little, what that means i dont know
Old Oct 1, 2022 | 07:56 PM
  #45
kr98664's Avatar
Okay, making some progress.
Don't worry about the pressure readings for now. I've seen too many instances of guys getting led astray chasing numbers on a dial. The troubleshooting guide deliberately stays away from pressure readings as much as possible.
Have you tested the DCCV again after your repairs? Don't fall for the trap of convincing yourself it must be good now because you found and repaired one fault. There may been more than one active fault.
Therefore, please keep working through the troubleshooting guide. Make sure to repeat the test of the DCCV, and then proceed from there based on the current symptoms:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Old Oct 12, 2022 | 09:38 AM
  #46
knares's Avatar
ok guys an up date
first i would like to thank all you guys that helped me, i didnt have a clue
i didnt get it fixed and as winter was coming on i just left it
well summer is just around the corner and as i am lade up with a cruck leg i thought i would have another go
this time i looked at it a bit closer and managed to fix it, fixed the A/C as well
every thing works fine, couldn't be happier
left it for a couple of days and went to start it, flat battery
jumped the battery and heard the heater fan was on
now when i park the car, every thing is off but later the fan is running
put the key in the ignition and turn it on and the fan stops
any ideas
thanks
kbeachy
20
May 20, 2021 11:18 PM
bniland
35
Oct 15, 2015 07:09 AM
dericksmith
Feb 17, 2012 07:32 AM
AngryJagOwner
Oct 21, 2009 04:31 PM
