Heater??
Old Oct 20, 2009 | 08:21 PM
AngryJagOwner's Avatar
Default Heater??
So does our car have a heater???
It got cold here in Florida and I tried to turn on the heater and nothing but cold air came out no matter the setting?????
any ideas???
Old Oct 20, 2009 | 10:04 PM
carelm's Avatar
Hi AngryJagOwner,
It could be a Heater Control Valve issue. Try to set the heat all the way to HI and see if that works. Also you might want to play around with the mode settings to see if that helps. I normally manually set mine to blow out the face and foot vents first and then maybe go to Auto if it's damp out.
Here is some message traffic that might help:
https://www.jaguarforums.com/forum/s...blem#post94140
Mike
Old Oct 21, 2009 | 05:03 AM
JOsworth's Avatar
Originally Posted by danielsatur
The dual heater control Valve (DCCV) provides both the driver and passenger control for heat, it's not unusual for one to go bad especially in florida.
Actually Heat being in the off pos, will isolate, the hot coolant from going into the heater core, so you have better cooling during summer months.
These electric type selonodes need to by exercised during the summer months,or they will seize or lock-up in the closed pos.
see https://www.jaguarforums.com/forum/thread.php?t=27185 also.
Holy Smokes! A well written and helpful post. Daniel is very correct. Since there is no heat at all I wouldn't think it is the cabin temperature sensor, but those are known to go bad as well.
Old Oct 21, 2009 | 07:11 AM
tbird6's Avatar
Try this first. Lack of heat is not usually caused by the DCCV but the AUX coolant pump. If you rev up the engine and hold it at 2000 rpm with the engine warm do you now get at least some heat?
Next check the coolant level. If low it could be your problem.
Report back on what you find.
Old Oct 21, 2009 | 04:09 PM
Coolant is fine,
Engine had been running for a while. I went for a drive when the cool front hit and it was about 55 out. I figured I would put it on outside air and turn the fan on with temp at 89. It was still blowing cool air when I got home.
but my seat heater works???
Is there a fuse that controlls just the heater??
thanks for the replies.
jazzman20014
Oct 26, 2015 04:15 PM
xjrjag
Oct 12, 2015 03:16 PM
inactualis
Oct 2, 2015 11:13 AM
dickc
Sep 21, 2015 02:04 PM
