Heater A/C issue
Old Apr 16, 2018 | 06:16 AM
Cobbler's Avatar
Default Heater A/C issue
My ‘03 s-type stared blowing hot air out of the left vent of the dash. Some guys at a local repair shop they’ve seen it with certain ford products where the heater box warps and I guess it jams some doors for redirecting heat/ac air. They said it’s big money to fix, like more than resale value type money. Any ideas besides replace the heater box. Maybe control valves? Appreciate reply’s in advance...
Old Apr 16, 2018 | 07:22 AM
aholbro1's Avatar
I'd stay away from those guys and that shop.
I must say I'm a bit baffled you could be here nearly 8 years and not be further along the learning curve on the S-Type HVAC than you are! If you've had that 03 S-T since you joined in 2010, you've been truly blessed to be facing this issue only now.
Use Search to find Karl's epic HVAC troubleshooting thread and it will set you on the right path. Sorry, but his username is KRwxyz where wxyz=some number sequence I can't remember - think it has maybe a 9, 8, and 7 in it but I can't recall what order...so can't help you much with Advanced Search; but the thread should be easy enough to find with keywords: Try DCCV, HVAC, and maybe air conditioning or heater.
Or I imagine Karl will be along shortly to direct you to it. All things are possible, of course, but I've not heard of anyone replacing the HVAC case to mend an S-Type heating/cooling issue....ever!
Old Apr 16, 2018 | 08:38 AM
NBCat's Avatar
+1 on never having to remove the heater box assembly other than for an X200 with a leaking evaporator core.
Use the search function to find relevant information:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Old Apr 16, 2018 | 11:29 AM
kr98664's Avatar
Any ideas?
Stop by your local shoe store and pick up a pair of good quality running shoes. Don't skimp, get a good name brand. You will need them for running at top speed away from this shop.
Even if they offer to do the job for free, do not let those mouth-breathers touch your car. Temperature control is done by modulating coolant flow through the heater core. There is no door for temperature control.
Looks like Norri beat me to it, but this link should steer you straight:
Post #2 details how to test the DCCV, the most likely cause.
Old Apr 17, 2018 | 06:51 AM
aholbro1's Avatar
Wait....NBCat is just Norri by any other name?
Old Apr 17, 2018 | 07:38 AM
kr98664's Avatar
My bad. Sorry, I was less correct than usual.
Old Apr 17, 2018 | 03:41 PM
Cobbler's Avatar
Thanks KR......you said a cup of coffee huh? More like a pot! LOL!!! Still reading it and will get to the meat and potatoes soon. Keep you posted, wish me luck.... and thanks for this, my hopes are much higher now.
kthrash
Dec 31, 2018 11:31 AM
JagSTL28
Jan 19, 2014 01:24 PM
shanshan
Dec 8, 2013 10:10 AM
SeldomJAG
Oct 11, 2011 12:21 PM
