HELP! My Compression Test...how bad?
Old Aug 5, 2012 | 08:01 PM
Studio19's Avatar
Default HELP! My Compression Test...how bad?
My car overheated and my wife had to drive it about a mile to safely get off the road. Anyway, it runs rough so I pulled the spark plugs and ran compression tests. The results are as follows, how bad is this....
Passenger Side Front to Back
130
130
65
120
Driver's Side Front to Back
130
80
115
120
Old Aug 5, 2012 | 08:20 PM
bfsgross's Avatar
May have warped the heads thus low on compression due to leakage and/or burned valves. Check coolant for exhaust odor and oil for water.
Old Aug 5, 2012 | 09:30 PM
abonano's Avatar
130
130
65
120
130
80
115
120
Unfortunately, those compression results are not good Studio19 - +1 on bfsgross feedback - but regardless whether the issue turns out to be warped heads, burnt valves or other internal damage (piston, piston to valve damage, bent valves, etc) - the above is very troublesome and you will have some tough decisions to make dependent on mileage/age of vehicle. (rebuild engine - if possible or install a used engine) - both of which are grossly expensive for the V8 engine.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
bdboyle
Sep 16, 2019 05:58 PM
knightofgold
Feb 11, 2016 06:03 PM
Arlo
XK120 XK140 XK150
Nov 1, 2015 05:44 PM
xjrjag
Oct 12, 2015 03:16 PM
