Help! Stuck in Park! no park lites blinking
Hi you need to get an old laptop and then it will work. I have an old 32 bit running on Windows 7. It can never be connected to the internet. Do not copy and paste the user name. Make sure that you write it exactly same. If you need more help pm me.
Any help in Maryland ? some one that has the software and can connect up? .
Im going to end up unloading as is if I cant get some help. Iv checked all the fuses reset several times . taken shifter apart cant find anything wrong with it. the car will start and shift when I release the solenoid. I have no clicking going on Like I used too when I hit the brake to shift also e brake doesn't release Unless I do It Manually. I also Have no Blinking red Lite on j gate as before I did. also small cable going to Ignition dosn't release or move when I start car or press on Brake.
Brake lites are working
Back up sensors are working
Reverse lites are working
only thing I havn't checked is cruise control.
