Here we go again now airbag light
Old Apr 5, 2023 | 02:33 AM
Darrol2004's Avatar
Default Here we go again now airbag light
After taking my 2004 s type for a warrant of fitness
which they failed as they said abs light was not working
which I believe was working but they know best
And said no symbol with abs came on or off
So I removed the instrument cluster took back off and
And then got a light to see what symbols were on cluster
I could not see any that say abs the light I told them I thought was abs was correct
Now after installing the instrument cluster
I have my airbag light flicks on and off then stays on
the code i have is b2293
it was working perfectly before cluster was removed
any help would be greatly appreciated
Thanking you
Old Apr 5, 2023 | 04:45 AM
JagV8's Avatar
The DTC PDFs are part of JTIS - free download.
Same as Ford though so you can web search such as
Ford B2293
Also in http://www.jagrepair.com/images/TSB/...t%20System.pdf
Could be driver or passenger.
Maybe you disturbed a wire...
Old Apr 5, 2023 | 08:15 AM
motorcarman's Avatar
Info for you.
File Type: pdf
File Type: pdf
Old Apr 6, 2023 | 05:22 PM
clubairth1's Avatar
Community Influencer
Drivers side airbag code? Maybe a clock-spring? Anything else that is controlled by the steering wheel switches acting up? Cruise?
Magbor123
Oct 12, 2022 09:04 PM
dneu
Jun 13, 2021 04:32 PM
Terryble
Feb 4, 2021 03:38 AM
Rytis Jankauskas
Oct 22, 2019 10:21 AM
johannes
Jan 16, 2013 10:28 AM
