Hi I need your help
Old Jan 8, 2013 | 10:07 PM
sws805's Avatar
Default Hi I need your help
I have S type 2001 3.0
Few days ago, my car did not start or ignition.
It still cranked so I put the gear into N with foot on accelerator.
It did started after trial couple of times
Furthermore, the door sliding seems slow and jammed like weak voltage?
I have changed the battery a week ago as it was drained out.
While driving, the car showed battery sign and I almost could have been died.
Do you guys have any idea of this symptoms?
Thank you
Old Jan 9, 2013 | 02:08 AM
JagV8's Avatar
Sounds like either not charging properly (such as wiring problem or faulty alternator) or a constant drain (faulty wiring or whatever). It might be a bad new battery, though not so likely.
Check voltage at battery terminals with car running to see if it's being charged. To check for a constant drain is more trouble so read the details in previous threads (Search to find).
Old Jan 9, 2013 | 07:58 AM
abonano's Avatar
+1 to JagV8 - especially regarding having a failing or "failed" alternator - additionally, after sorting out the charging issue - you should look into the long cranking issue - sounds like a partially clogged fuel filter (hopefully) or a failing fuel pump...
Old Jan 9, 2013 | 11:50 AM
tbird6's Avatar
What's a door sliding?
Old Jan 9, 2013 | 12:00 PM
police666's Avatar
i don't know but i want them !!! pugeuot 1007 style
Old Jan 9, 2013 | 02:40 PM
bfsgross's Avatar
"Sliding Door"? Perhaps the OP believes he's on the Dodge Caravan forum?
Old Jan 9, 2013 | 02:59 PM
Jagtastic's Avatar
I think, perhaps, the OP is trying for 'window regulator'.
