High Idle
Old May 25, 2007 | 08:48 PM
badmojo's Avatar
Default High Idle
Hi,
Does anyone know if it's possible for the dealer to go into the ECU and adjust the in gear idle ? My 03 str is pulling a little hard in drive when I have the brakes on and when I take it out of gear the idle jumps up about 150 rpm before it goes back down to rest at about 650 rpm. does anyone else have this issue?
Old May 26, 2007 | 12:00 AM
nti06's Avatar
Default RE: High Idle
most likely you have a sticking idle air control motor. or your entire electronic throttle body is taking a **** on you.
Old Jun 30, 2007 | 11:34 PM
badmojo's Avatar
Is the idle air control motor something that I can get access to myself and check it out?
Old Jul 5, 2007 | 11:28 AM
badmojo's Avatar
Thanks, I'll do that! I have brought it to their attention several times but no luck. I wouldn't mind so much if the car didn't want to pull so hard when I put it in drive and reverse and when I come to a stop. If I let off of the brake It will go up to 6 + mph right away and when I stop it shifts into first just as I'm about to stop and causes it to jerk forward. It really moves fast in reverse! Is it possible for them to simply adjust the in gear idle thru the ECU or the TCU? They tell me that there are no codes showing up but this didn't start happening until after ther did a hard reset of both.
hoodun
Nov 20, 2022 02:35 PM
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
JCam
Oct 23, 2016 08:27 PM
driver safz
Sep 26, 2015 06:01 AM
