How to advance idle speed v6
Old Aug 19, 2017 | 06:44 AM
SANDSHARK's Avatar
Question How to advance idle speed v6
Hi Guys, 1999 AUTO - S-Type 3.LT V6, how and where are you able to adjust the idle speed, have searched forum but cant find anything
I dont have any fault codes, its just a question before I go looking for myself
thanks
Steve
Old Aug 19, 2017 | 08:37 AM
JagV8's Avatar
You're not meant to need/want to do that - what is it that makes you wish to do so?
(You are likely to cause codes if you do...)
Old Aug 21, 2017 | 05:18 PM
clubairth1's Avatar
Community Influencer
As JagV8 said the computer controls it so no adjustment.
Are you having problems?
Old Aug 30, 2017 | 04:12 AM
SANDSHARK's Avatar
Hi Guys, I suspect that the Elbow under the rear of the intake manifold is now leaking, not bad at this stage, the idle is still ok for around 2-3 mins, and with only a few hesitations until she just cuts out, she seems to and has always sat at 700 rmp, but if i take her up to 900 she will sit on idle forever. it does not really bother me that much, just means that I have to give her a rev or two while sat at traffic lights, but was just wondering if i could adjust to simply compensate, i was thinking more about the actual pedal / cable,
Old Aug 30, 2017 | 06:48 AM
joycesjag's Avatar
Just fix the darn leak. You will only end up costing yourself more headaches and money in the long run!
There is informative DIY here or at Gus's site. www.jagrepair.com
Old Aug 30, 2017 | 07:12 AM
JagV8's Avatar
the perished hose will get worse and vary with vibration so anything will fail except if you fix the hose!
Old Aug 30, 2017 | 08:03 AM
Mikey's Avatar
There is no cable. It's an electronic signal/drive by wire system. Fix it properly- this problem will just get worse.
