How can I manually move drivers seat?
Old Oct 27, 2015 | 07:24 AM
1003pv's Avatar
Default How can I manually move drivers seat?
Hi,
The fore and aft motor for the drivers seat of my Jaguar S-type has jammed. The seat will not move backwards or forwards. I can hear the motor click when I activate it and all other seat adjustment motors are working fine.
I need to remove the seat to replace the motor, I can easily undo the front fixings but the rear ones are hidden by the seat. I need to manually move the seat forward to expose the fittings. Any ideas on how I can do this?
Old Oct 27, 2015 | 02:36 PM
leaping cat's Avatar
Would be good to know your MY
Old Oct 27, 2015 | 05:02 PM
1003pv's Avatar
It is a late 2002 2.5SE auto
Old Oct 28, 2015 | 03:20 AM
Mine is the earlier version so might be different. But try this: there could be two screws in the front connecting the seat to the moving mechanism. Unscrew these and carefully remove the rubber rings. Now push forward the seat. It will not move first but if you see what is blocking movement in the front you can free up the movement with a screwdriver as a lever.
skeena river rover
Oct 31, 2016 01:43 PM
Geggen
Oct 27, 2015 01:30 AM
JaguarSV8
Oct 25, 2015 01:47 PM
dollison
Oct 24, 2015 04:21 PM
280zx-turbo
Oct 21, 2015 05:22 AM
