How to decode the 4.0l motorcode? (4.0l AJ28 from MY2003 in S-Type MY2000 ?)
Old Apr 23, 2014 | 12:36 PM
Kupferglanz's Avatar
Default How to decode the 4.0l motorcode? (4.0l AJ28 from MY2003 in S-Type MY2000 ?)
Hi guys,
I´ve to swap my engine in my S-Type 4.0L MY2000 (german S-Type). I´ve the option to buy a 4.0L AJ28 from MY2003 (UK model). But I´m unsure, if this motor will work in my S-Type from MY2000.
I´ve seen, the ECUs in the 2003 S-Types differs from the earliers models. Is it right, that the Jaguar changes the firing order in the AJ28 4.0l in 5/2002 ?
So, I got the motorcode from the local dealer for the 2003 engine, but how can I decode it? Perpaps it´s a 4.2l (not a 4.0l) or the engine has the changed firing order and it can´t work with my ECU?
Thanks for your answers :-)
Tom
Old Apr 23, 2014 | 01:10 PM
JagV8's Avatar
By 2003 in UK all would be 4.2. It's possible but not easy to convert and there's a detailed thread in another forum on this site in case you want to consider it.
I believe the actual firing order stayed the same. What changed was the way the cylinders are numbered but if you look at the two firing orders and allow for the changed numbering they work out the same.
What's wrong with the existing engine?
Old Apr 24, 2014 | 01:07 AM
Hi,
the crank shaft bearings in the existing engine are broken and there is piston squeezing too. No chance to rebuild, that´s what Jaguar said to me.
If the new engine (2003) is the last version of the 4.0l V8 engine in the S-Type (with the new ECU), would it fit in my MY2000 S-Type (1st generation V8 4.0l engine) with the old ECU?
Today I´ll search for some threads, where the changes in the AJ-28 engine are listed and I´m searching the engine conversion thread, you told me. Thanks.
How can I check with the motorcode on the engine, if it´s a 4.0l or a 4.2l engine? The engine number on the 2003 engine is: *LFACF*BBAA* *LSNMK*
There is no VIN available, where the new engine is dismounted from, I only know it´s a S-Type MY2003 from UK and has the new ECU. Is not the same than my ECU, it´s complete different :-(
regards,
Tom
Old Apr 24, 2014 | 01:38 AM
JagV8's Avatar
If it's 2003 it's going to be 4.2 as the change was in 2002 here (UK).
Old Apr 24, 2014 | 02:39 AM
Thanks, I´ll check it and give you a feedback :-)
Clare Jennings
Oct 4, 2015 05:43 PM
baskervillema
Oct 1, 2015 06:43 PM
dpappyp
Sep 29, 2015 01:28 PM
