How to fold my Mirrors?
Old Jun 27, 2007 | 11:28 AM
badmojo's Avatar
Default RE: How to fold my Mirrors?
I have an 03 str and all i have to do is push them either frontwards or backwards. They are pretty stiff and make some noises but they do fold? Be sure to do this carefully! Be sure that they are 2 piece. The mirror folds, not the bracket coming off of the door.
Hope this helps.
Old Jun 27, 2007 | 11:53 AM
04Xtype's Avatar
I dont think the 03's have power fold mirrors, so it should be as badmojo says, just fold them by hand.
Old Jun 27, 2007 | 12:00 PM
badmojo's Avatar
Never heard of POWER folding mirrors before!
Old Jun 27, 2007 | 12:33 PM
Igloo112's Avatar
I think Ckehayov is talking about the power folding mirrors. I have heard of them. You would have to press the mirror button back once and they automatically fold back. Pretty sweet. But if that's not working, the old fashion way is the way you're gonna haveto go.
Old Jun 27, 2007 | 03:51 PM
DEBBIE's Avatar
Well I've only had my Jag 4 weeks and it's an X not S type BUT it does have power fold wing mirrors and they are activated by a small button just above the mirror positioning buttons. Would assume that this is were yours would be if you had the option fitted.
By the way HELLO!
Old Jun 28, 2007 | 05:57 AM
04Xtype's Avatar
Welcome Debbie, where do u live, in europe or the states? cos im pretty sure that only the
X's in europe got the option of the powerfold mirrors due to the small roads and being able to park on the streets. Here in the states they arent really necessary, but i sure as hell would like them on my X, they look sick when folded, and when folding. How are you liking the X so far?
Old Jun 28, 2007 | 10:12 AM
DEBBIE's Avatar
I'm in the UK.
They are essential in UK Supermarket car parks as we brits are getting bigger but the spaces aren't.I love just pressing the button when I park up and watch them tuck themselves away but as I've not had the car very long I have on a couple of occassions driven off without unfolding them, lol, I've gone to check mirrors before pulling out and found myself looking at ME! [sm=smiley30.gif]
Old Jun 9, 2010 | 09:27 AM
ChrisSTR's Avatar
Question
My 03 str's manual says i have power fold but it isnt working. Im scared to push on the mirror too hard. What gives?
Old Jun 9, 2010 | 09:32 AM
ccc's Avatar
ccc
I believe the non-power folding mirrors are designed to fold when it hits something so its rather hard to fold. I not too sure its designed to be manually folded on a regular basis but if you do, i'm sure it will loosen up over many folding cycles.
Old Jun 9, 2010 | 11:52 AM
tbird6's Avatar
Power folding mirrors were an option on the S Type. Much more common in UK and Europe. I have seen a couple in Canada and US. If you have them then this is how they operate.
Put the switch that selects which mirror (Divers/passenger side) in the middle position. This normally makes the 4 way switch that moves the mirrors up/down and in/out not work. Then using the 4 way switch push in the direction to fold the mirrors in. This will move both mirrors at the same time and will now fold in all the way. If nothing happens when you do this then you do not have the folding mirror option.
I have read where someone added it to their S Type. The problem is another wire had to be added going into the door. It was thought in the beginning that the feature was there but just had to be enabled by the dealer.
Old Jun 9, 2010 | 12:02 PM
JagV8's Avatar
To clarify (I hope), put the rocker switch tbird6 mentions in its central position, then press the rearward part (bottom pimple) of the circular button at the front of the driver's door switch pack.
Old Feb 21, 2015 | 01:02 PM
Moggie07's Avatar
Default Folding mirrors
I used to have a 2.5 s type se 2004 this had folding mirrors,i now have a 2006 3.0 sport and this does not have the folding mirror option.
Old Feb 21, 2015 | 03:18 PM
jpvd's Avatar
My 2000 plate has power fold mirrors. Button is located on drivers door, on lower storage bin...
Press it and the mirrors fold in...
Old Feb 22, 2015 | 04:29 PM
Sir Arthur Streeb Greebling's Avatar
tbird6 is spot on - they were an option and work just like he says. When I got my car the power fold was not working, it took a fair bit of WD40 to get them going again. I took the mirror glass off, the fold motor was quite well corroded, it seems to be made of an alloy that suffers from corrosion. Copious quantities of WD and working the mirrors backwards anf forwards did the trick. Be careful that you don't get the wd on your paintwork, it can damage it.
Old Feb 23, 2015 | 04:39 AM
rd350ypvs1972's Avatar
My 2002.25MY (2003) str has powerfold mirrors
Old Feb 23, 2015 | 09:05 AM
Ingo's Avatar
How did you take off the mirror? do they pop off?
Old Feb 24, 2015 | 08:18 AM
ManoFlem's Avatar
After reading the threads on this the other day I immediately went out and tried it on my car. It didn't work. Would love it if they did. Does anyone know if the dealer can activate this for you?
Old Feb 24, 2015 | 09:34 AM
JagV8's Avatar
It was an option. Did you buy a car with it?
