How many miles are on your S?
Old Nov 23, 2012 | 06:28 PM
  #41
maxthrottle's Avatar
Default 99999 on the 2003 STR
Old Nov 23, 2012 | 08:44 PM
  #42
ducducjag's Avatar
Default 40k 2003
Original owner, '03, manual 5-speed; just turned over 40K mi. Driving split between several vehicles and motorcycles, but driven with relative frequency. Routine maintenance and no performance problems; love it like day one!
Old Nov 24, 2012 | 08:02 AM
  #43
Jon89's Avatar
Now at 73,250 miles....
With me now splitting my driving needs between our S-Type and my Dodge Ram pickup, it appears that our S-Type is now on pace for between 6,000 and 8,000 miles per year....
Old Nov 24, 2012 | 09:47 AM
  #44
jkdahlman's Avatar
2001 4.0 145K.
Drives beautifully & looks great, but the heat is giving issues. Had to happen eventually.
Old Nov 24, 2012 | 12:26 PM
  #45
jimgoose's Avatar
Originally Posted by jkdahlman
2001 4.0 145K.
How d'you mean - you ask for heat, but get no heat? The DCC valve packs up in them. Replace it with one of these:
<b><i>http://www.amazon.com/Motorcraft-YG355-Heater-Valve/dp/B000C5HZEM/ref=sr_1_2?ie=UTF8&qid=1353781497&sr=8-2&keywords=Motorcraft+Jaguar+S-type+valve</i></b> http://www.amazon.com/Motorcraft-YG355-Heater-Valve/dp/B000C5HZEM/ref=sr_1_2?ie=UTF8&qid=1353781497&sr=8-2&keywords=Motorcraft+Jaguar+S-type+valve
The part number you want is YG355.
Old Nov 25, 2012 | 12:58 AM
  #46
1320racer's Avatar
Default 2005 STR w/ 74K miles
I have had my STR since 7K miles and now have 74K miles. I've replaced the following items:
  • Tires - Continental SportContact 2, Toyo Proxes T1-R and two sets of Continental DWS
  • Brake Pads - Akebono front/rear brake pads and still using original rotors (anybody else use their OEM rotors for this long?)
  • Battery - AutoZone
  • Water Pump - Failed and replaced the following at the same time for preventive maintenance...DCCV, Serpentine Belt and Idler Pulley
  • Plugs and Coils - Replaced all but did not need to. Misfires and performance issues were caused by bad catalytic converter
  • Catalytic Converters - One failed and replaced both with aftermarket, now running both OEM again. Aftermarket Magnaflow cats failed and they were too loud anyway
  • Radiator Fan - Replaced due to failure
  • Gas Tank Plastic Seal Cap - Failed under rear passenger seat
  • Heater Hose under SC - Replaced but appeared to be in very good condition. Since I had it apart I replaced the following items too...SC Pulley (Replaced with 2.6 inch/3.0 lb.), SC gear oil, many Gaskets and Hoses
  • Inner Tie Rods - Replaced both sides, one side was bent
  • Motor Mount - Diver's side failed
Old Nov 25, 2012 | 12:59 PM
  #47
Staatsof's Avatar
You think you could put some mileage markers next to those repairs? Mine has a lot less miles but I'd like to know when to be "out of town" when those things hit ... LOL
Old Dec 10, 2012 | 07:23 PM
  #48
eastwildlife's Avatar
'01 4.0. 81k. Bought her two years ago with 79k. Right cat flipped code for efficiency, anti fouler fixed it. LF window reg from an LS, front sway bar bushings, left spindle for bad ball joint, Ouch! LF wheel bearing. Currently sleeping undercover and waiting on spring.
Old Dec 10, 2012 | 08:08 PM
  #49
chucky60's Avatar
Default Not much
2000 s type 4.0 . 55,500
Old Dec 10, 2012 | 09:44 PM
  #50
yo_odie's Avatar
I have 72k on it and replaced the battery and the ac relay
Old Dec 10, 2012 | 10:29 PM
  #51
FunJag's Avatar
Default 2001 3.0....
122,213 and loving it. Same problems as everyone, but my wife will not let this car go and I am actually very fond of it too. Lovin' my Jag.
Old Dec 11, 2012 | 07:45 AM
  #52
Michael Star's Avatar
03 STR 71k miles
Old Dec 11, 2012 | 08:55 AM
  #53
hedgehog's Avatar
Default milage
113500 diesel s type, running good and strong
Old Dec 13, 2012 | 10:26 PM
  #54
Soccer6planer's Avatar
2000 S-type 4.0 149,000 New tranny about 2 years ago
Old Mar 17, 2015 | 09:43 AM
  #55
1320racer's Avatar
Default Late... mileage info and updates
Mileage info and updates…
  • Tires - Continental SportContact 2, Toyo Proxes T1-R and two sets of Continental DWS, edit/add: ~92k miles on third set of Continental DWS and need to change again
  • Brake Pads - Akebono front/rear brake pads and using original rotors (anybody else use their OEM rotors for this long?) edit/add: changed at ~22k miles,
    edit/add: now at ~92k miles, still with the Akebono front/rear brake pads and still using original rotors, everything may need changed this Spring, 2015.
  • Battery - AutoZone, edit/add: ~40k miles
  • Water Pump - Failed and replaced the following at the same time for preventive maintenance...DCCV, Serpentine Belt and Idler Pulley, edit/add: ~30k miles
  • Plugs and Coils - Replaced all but did not need to. Misfires and performance issues were caused by bad catalytic converter, edit/add: ~45k miles
  • Catalytic Converters - One failed and replaced both with aftermarket, now running both OEM again. Aftermarket Magnaflow cats failed and they were too loud anyway, edit/add: ~50k miles
  • Radiator Fan - Replaced due to failure, edit/add: ~55k miles
  • Gas Tank Plastic Seal Cap - Failed under rear passenger seat, edit/add: ~50k miles
  • Heater Hose under SC - Replaced but appeared to be in very good condition. Since I had it apart I replaced the following items too...SC Pulley (Replaced with 2.6 inch/3.0 lb.), SC gear oil, many Gaskets and Hoses, edit/add: ~60k miles
  • Inner Tie Rods - Replaced both sides, one side was bent, edit/add: ~30k miles
  • Motor Mount - Diver's side failed, edit/add: ~60k miles
  • Coolant Tank - edit/add: ~85k miles
Last edited by 1320racer; Mar 17, 2015 at 09:47 AM. Reason: correct and update mileage
Old Mar 18, 2015 | 07:14 AM
  #56
Sonspit's Avatar
2004 jaguar s type v6 3.0
122,xxx changed 3 coils+ plugs/ac doesn't blow cold/check engine light on throwing different codes randomly and suspension making noise but runs beautifully.. looks brand new inside and out
Old Mar 18, 2015 | 08:06 AM
  #57
rd350ypvs1972's Avatar
02 str 46500
Old Mar 18, 2015 | 08:31 AM
  #58
Jon89's Avatar
2005 S-Type 3.0 now pushing 88,000 miles....
It's been relatively trouble-free the past year or so. We did its first ATF drain-and-fill last November at just over 85,000 miles. I felt it was time and I went with Mercon SP (which has done quite well). Just put the car in the shop this morning to have the A/C system checked out. It has been blowing ambient air for the past few weeks and with afternoon temps now reaching into the 80s on some days, I'm sweating like a pig even with the windows down. This polar bear can easily live without heat but I cannot survive without A/C....
Old Mar 18, 2015 | 08:48 AM
  #59
pab's Avatar
pab
'08 4.2 58K miles (got it 05/13 with ~48K miles)
Had to replace both HID headlamps, one under warranty one not... =:-0
Also replace the front fender liners because the were both badly cracked.
Did pads and rotors
Just now the radio speakers have stopped working
Jaguar - it's not an automobile, it's a Motorcar
Old Mar 18, 2015 | 02:51 PM
  #60
Dino V's Avatar
Just hit 49k miles on my '05
