How many quarts of power steering fluid does the s-type use?
Old Nov 25, 2012 | 06:36 AM
daboss085's Avatar
Default How many quarts of power steering fluid does the s-type use?
I wanted to do a p/s flush, how many quarts should I go buy? thanks guys.
Old Nov 25, 2012 | 09:00 AM
clubairth1's Avatar
Community Influencer
If you download the manual (JTIS) from this site it will have this and a bunch more information. Plus it's free. Look at the threads at the top of the list to find it.
Old Nov 25, 2012 | 10:41 AM
msnyder52's Avatar
Looks like the capacity is 1.6 quarts of Dexron 3.
Old Nov 26, 2012 | 03:25 PM
heima's Avatar
At the bottom of the steering rack is a hose about two feet long with a plug at one end. I removed this plug to drain the fluid, turning the streering wheel slightly to speed up the drain process. The engine was turned off. About 1.6 quarts drained. I capped the plug with a hose clamp and then refilled the resivior. Working the.streering wheel did not lower the fluid (get the air out). So I started the engine and immediately turned it off. This lowered the level. I added more fluid and started and immediately stopped the engine. After the third time, the fluid level seemed to stay. I started the engine again and worked the steering from lock to lock. Somewhere I read that bouncing the steering.off the end stops will bleed air from the system, so I did that.for a while. After that was done, only a tiny bit more fluid was needed.
Techs, if I am providing bad advice, please let me know.
Old Nov 26, 2012 | 05:02 PM
daboss085's Avatar
so all I really need is to buy 2 or 3 quarts of dextron 3 for about 5 bucks a piece and thats it? dosent sound bad then
Scarecrow
Mar 28, 2016 03:17 AM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
