how to re-attached light bulb clip
Old Mar 5, 2018 | 11:16 AM
MyGreyJag's Avatar
Default how to re-attached light bulb clip
2004 S-TYPE, 3.0, Base model,
I removed the retaining clip to replace a blown low-beam bulb. Very easy. I am having extreme difficult attempting to re-attached the retaining clip. Is there a proper procedure or maneuver I should be aware. I can't get the wire ends (open side) securely in place.. Thanks for any instructions on how to ease my pain. Your assistance is greatly appreciated.
RAC, Grey 2004 Jag S-Type, 3.0, Base
Old Mar 5, 2018 | 11:33 AM
NBCat's Avatar
Is it the correct bulb and is it fully in position?
Old Mar 6, 2018 | 08:07 AM
leaping cat's Avatar
The proper procedure would have been not to remove the clip in the first place.
It is almost impossible to reattach. Maybe a good gynecologist can help.
Old Mar 7, 2018 | 03:29 AM
R2e's Avatar
R2e
I had a clip come off while I was fitting LED bulbs. No matter what I tried (and I am not a gynaecologist....) I ended up removing the bumper, taking out the headlight and putting the clip back in. Approximately 2 hours to remove and replace bumper and headlight (had problems with the undertray to bumper screws/clips which were seized) 2 minutes to put the clip back in once I could see what I was doing and had unlimited space to work in!
Old Mar 7, 2018 | 03:52 AM
If it is on the side where the air filter is, removing the filter box might help.
Old Mar 7, 2018 | 05:39 AM
I found a light and a mirror a big help.
JimC64
Sep 22, 2025 02:52 PM
Drossvet
Oct 21, 2016 09:27 AM
CTH Automotive
Oct 10, 2016 09:39 AM
JimC64
Sep 10, 2009 12:44 PM
Jan 22, 2006 12:18 AM
