How to Remove the Instrument Cluster on a 01 S-type
Old Oct 26, 2011 | 08:10 PM
Sal16's Avatar
Just did mine. Remove airvents. they're held in by pushclips. behind drivers side and center ones are screws. behind passenger one is a metal bracket. Remove screws and slide metal bracket to right (may take some effort). Remove woodgrain facia and you'll see 4 screws holding instrument cluster. that's it
Old Oct 26, 2011 | 08:34 PM
bmw745ion19s's Avatar
i can help you with my baseball bat or crow bar, your choice lol other hten that im useless thank God for our other forum members who do everything!
Old Sep 18, 2012 | 01:21 PM
acerek's Avatar
is it the same for the X-Type? I need to replace mine. Tks!
Old Aug 3, 2014 | 01:32 PM
webbeing's Avatar
Hello,
I am stuck on removing the wood panel. I removed all the vents and screws. But the wood panel stuck quite tightly on the passenger side. In the below pic, do I suppose to pull the metal bracket (circled in yellow) to the right? I actually put quite a bit of pulling force but the bracket did not move. Thanks for any help.
Attached Thumbnails How to Remove the Instrument Cluster on a 01 S-type-pvent.jpg
Old Aug 3, 2014 | 01:42 PM
webbeing's Avatar
I just did it. I had to use quite a bit of force to pull to the right that bracket, which free up the two pins behind the wood panel.
redrover41
23
Sep 25, 2015 01:33 PM
mrplow58
Sep 9, 2015 11:27 AM
jaguarbill
Sep 5, 2015 11:43 AM
martybmw
Sep 4, 2015 11:05 PM
AL NZ
Sep 4, 2015 08:39 PM
