I see big bills ahead :(
Old May 6, 2016 | 11:47 AM
rd350ypvs1972's Avatar
Default I see big bills ahead :(
Can anyone tell me what sound this is going to cost me ?
After a little spirited driving in manual sport mode it just all of a sudden started making that noise
supercharger knackered ?
Engine ok ?
I have no MIL or DTCs so god knows
Any input please
Old May 6, 2016 | 12:28 PM
Mikey's Avatar
Wow, a Reliant Robin. Don't see many of those.
Old May 6, 2016 | 12:41 PM
lol
Old May 6, 2016 | 01:45 PM
Gus's Avatar
Gus
Sorry but unable to make out the noise but did you check for codes? Did you turn the car off or did it shut down on its own?
Old May 6, 2016 | 02:06 PM
JagV8's Avatar
And I suppose - what noise does it make in the engine bay with bonnet (hood) up?
Also, make sure where any odd sound is coming from as quite often the actual source is not where first suspected.
Old May 6, 2016 | 02:29 PM
Datsports's Avatar
You can easerly remove the s/c belt and spin the s/c back and forth to see how it feels !
Sure hope it is the s/c and not the engine . good luck .
Old May 6, 2016 | 03:06 PM
will do another vid in the morning so you can get a better idea
The car starts first time, no mil warning lights, oil pressure ok, just sounds like someone is throwing rocks around in the supercharger the size of house bricks
Old May 6, 2016 | 03:28 PM
NBCat's Avatar
Rather than making videos, perform the procedure mentioned in the post above by Datsports to determine if there is an issue with the supercharger or elsewhere.
With the supercharger belt removed, you can listen to other components such as the water pump to determine the location of the noise.
Old May 9, 2016 | 12:23 PM
checked the oil and it took a whole 5ltr of oil, not a good sign. removed the supercharger belt and knocking still there so looks like no oil has caused a part siezure
I dont know why the oil pressure light worked as normal with no oil ???
ah well its gunna be expensive now
Old May 9, 2016 | 12:30 PM
Gus's Avatar
Gus
This does not sound good!
Old May 9, 2016 | 01:29 PM
STRV8's Avatar
Hi,
Sounds really bad. Could be oil cooler line massive leak and you drove it with little oil pressure with no warning light to show it. Replaced my lines cause little dripping to avoid totall failure.
Really hope your engine is not destroyed.
Old May 9, 2016 | 02:36 PM
NBCat's Avatar
Most likely damage to main and rod bearings and possibly gudgeon, or wrist pin(s).
Next step would be to remove the sump and inspect for metal particles, then check main and rod bearing condition.
Old May 9, 2016 | 06:30 PM
Mikey's Avatar
It would be interesting to know if the lack of oil was the cause of the engine problem or the result.
Old May 9, 2016 | 10:48 PM
STRV8's Avatar
Hi, I wonder why there was no warning light due to low oil amount/pressure ? Think such a huge lack of oil should trigger warning ?
Old May 10, 2016 | 01:27 AM
JagV8's Avatar
Eventually. Engine's toast before then on many cars.
The dipstick isn't really an optional item. Even then you can be unlucky.
Old May 10, 2016 | 08:23 AM
pab's Avatar
pab
Start shopping for a replacement engine, a rebuild of that motor would be mega-bucks (or pounds, if you will).
But seriously, I think, unfortunately, your car is toast. If you love STRs look for a later model and hope you can recover some of the cost by parting out your current car.
Sorry...
Understeer is when you hit the wall with the front of the car
Oversteer is when you hit the wall with the rear of the car
Horsepower is how fast you hit the wall, and
Torque is how far you take the wall with you
Old May 10, 2016 | 09:03 AM
clubairth1's Avatar
Community Influencer
Any idea when the oil was last checked?
Seems to be too low.
Old May 10, 2016 | 12:46 PM
I must admit I haven't had it checked since about 6 months ago. Since then it has been pulley upgraded, remapped and terracleaned so God knows when it was actually too low
Old May 10, 2016 | 01:04 PM
Jon89's Avatar
Regardless of the vehicle, you need to check your oil level at least every weekend. If you do not, you will never catch the unexpected leak that eventually destroys your engine....
Old May 10, 2016 | 02:12 PM
no point telling me that now lol, everyone else take heed
