IMT seals
Old Jun 21, 2011 | 08:05 PM
Remme's Avatar
Default IMT seals
I am a new member so I am not sure if I should have started a new thread for this question. I have a 2005 S-type and I changed the AC compressor today and that went well, My ac is working great now but I also changed the IMT seals because I had an oil leak. That seemed to go well but when I started the car I now get an engine light and a restricted performance notice. Any ideas what I could have done to cause this problem? Thanks.
Old Jun 21, 2011 | 09:25 PM
joycesjag's Avatar
Did you put the vacuum hose back onto the back of the intake manifold?
I'll find the picture.
Old Jun 21, 2011 | 09:41 PM
joycesjag's Avatar
Which way did you replace the IMTs, through thr cowl area or did you remove the intake manifold? Here the picture of the 2 vacuum line locations.
You can read more on this thread: https://www.jaguarforums.com/forum/s...-issues-46959/
Old Jun 21, 2011 | 09:54 PM
Remme's Avatar
I didn't remove the intake manifold and if I disconnected any vacumn hoses it was by accident. I just unplugged the electrical connector and then took the valves out.
Old Jun 21, 2011 | 10:01 PM
Remme's Avatar
Will check out tomorrow. Thanks for the picture.
Old Jun 22, 2011 | 03:31 AM
Cadillac's Avatar
Hopefully it turns out to be a cheap fix for you
Old Jun 22, 2011 | 08:07 PM
Remme's Avatar
Checked the vacumn hoses. They were connected. Started thinking about what I took off and put on when working on the AC and found a connector not plugged in. Thanks for the help.
prettydaim
Nov 12, 2015 08:05 PM
JungleJonny
Oct 5, 2015 03:52 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
hoodun
Sep 28, 2015 08:32 PM
