inertia switch
Old May 13, 2018 | 01:19 PM
mlstafford's Avatar
Default inertia switch
2005 jaguar s-type 3.0 had transmission work done, and a new battery put in. car still won't start. I've read several articles on getting new fuel pumps. Is the inertia switch possibly the cause?
Old May 13, 2018 | 07:45 PM
Datsports's Avatar
Try checking for fuel pressure first via obd2 .
Then if no pressure try pressing the inertia swich . And listen for a click .
And recheck the fuel pressure.
Also have a look at the pats light on the dash to see what that is doing .
And check the mechatronics plug on the trans is seated.
Did you by any chance replace the tcm . If so it will need programming before you can start it .
Old May 16, 2018 | 09:36 AM
clubairth1's Avatar
Community Influencer
Turn off all the radio/AC stuff. Turn on the key.
Can you hear the pump run for several seconds? You should be able to hear that and it will run a bit every time you cycle the key.
Let us know what you find out.
o2manyfish
Nov 11, 2016 01:03 PM
PanamaJag
Oct 29, 2016 02:19 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
gp1959
Jan 18, 2009 07:19 PM
gp1959
Dec 5, 2007 09:18 PM
