Injector Fuse Blowing
Old Sep 22, 2019 | 10:40 PM
Chris Edwards's Avatar
Default Injector Fuse Blowing
Just got this car for my daughter and giving me some issues. Just changed out the fuel pump and now the #5 fuse for the injectors keeps blowing every time we hit the ignition. FYI we had jump started or tried to several times.
Where can I start trouble shooting?
Old Sep 23, 2019 | 11:00 AM
kr98664's Avatar
Hello, and welcome to the forum.
What year and engine?
Wiring diagrams are at the top of this page:
http://www.jagrepair.com/JaguarSType...OBDIIcodes.htm
Once we know the year and engine details, we can walk you through some troubleshooting steps.
Don’t panic that you’ve got an active fault that keeps blowing a fuse. That’s much easier to isolate than an intermittent problem that comes and goes.
Does the fuse blow when you first turn the key to the run position, or only when you turn the key to start?
I’ve only got sporadic cell coverage the next week or so (camping trip) so please don’t be alarmed if I’m very slow to respond.
Old Sep 23, 2019 | 11:08 AM
kr98664's Avatar
Most likely your battery is now an ungainly paperweight. These cars are VERY sensitive to battery condition. If the battery had been sitting discharged any length of time, I’d plan on replacing it.
At the very minimum, fully recharge the battery and have it tested. Any place that sells batteries will do it for free. If bad, make sure the replacement is fully charged, too. They typically aren’t at the time of sale.
Old Sep 23, 2019 | 01:37 PM
Sorry about that....Newbie here
It is a 2000 S-Type with the 4.0. It blows when you go to crank the engine. Battery was extremely low so I took it out and put on a slow charge. Battery is almost new.
Old Sep 24, 2019 | 12:22 PM
A little update and part of the mystery solved. The piece shown on the throttle body below is missing. When trying to start the other day I covered with my hand and it ran. I put a piece to block air and it turns out it makes the #5 fuse blow. When removed it does not blow. Now to find that missing part and move on with life.
Any idea what to search for? The part that attaches to the vacuum on this side of throttle body.
Old Sep 25, 2019 | 10:50 PM
kr98664's Avatar
I put a piece to block air and it turns out it makes the #5 fuse blow. When removed it does not blow. Now to find that missing part...
Wow, that is very strange. No idea why that is happening.
The best thing I can suggest is to install that missing piece as you were thinking, and see what happens. Sorry I don’t know what that part is called. Maybe somebody with an early V8 can chime in.
Old Sep 26, 2019 | 03:02 PM
S-Type Owner's Avatar
Per Barratt's parts catalog, the missing part is a "Blanking Plug," part #NCE4826BA.
The catalog is available as a free download, BTW...
raschwar
Nov 15, 2022 01:45 PM
Terrance39
Apr 2, 2019 05:52 PM
Paulie63
May 29, 2016 07:29 PM
TGC37SR
Apr 13, 2016 04:01 PM
